Sometime4s printed copy comes out sometimes blank sheri also door will not close
SOURCE: Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
SOURCE: Printer does not print. Makes noises as though
OK the next thing i can tell you to do is try to clean the contacts use a q tip wit alcohol on it
