Question about Avaya 5610 IP Phone
Phone does not connect to IP
I have a 5610 IP Phone internet is working but Phone does not detect the IP thru the Ethernet cable pls help...
    Problem Solver:
  • 6 Answers
Replace the nic card or ethernet card.Mail me back at amu1974@rediffmail.com if the issue does not get resolved
Thanks and Regards
Amlan
Posted on Nov 16, 2007
How to set internet on it
if you are using IP phone, make sure that you connect the Ethernet cable (yellow cable) from the modem or router to the LAN part of it whereas another Ethernet cable (blue cable) is connected from the IP Phone to your PC Desktop.. This connection will surely connect your phone to internet and to your PC...
Feb 15, 2011 | Lands Phones
Internet problem thru ethernet cable
Hi
First thing I would check is try another ethernet cable, by any chance have you recently bought a 3G cordless phone, if so they operate at same frequency as the router!!
Cheers cbacer
Aug 11, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect belkin wireless adapter to my xbox 360 thru my pc
every computer has an ip adress you might have to go to your internet setting and find some thing that says some thing like... internet adress hook up hopefully you keep files on your computer becuase with out your ip adress you might not be able to hook up its sorta like a combination hope it helpes:)
Mar 02, 2009 | Belkin Video Game Consoles & Games
Cant automatically detect IP
First, connect your computer via an ethernet cable to the router to eliminate any problems with your wi-fi setup.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power on the computer.
  2. Open the Control panel and the Network Connections applet.
  3. You should see something called "Local Area Connection".
  4. Double-click on it and click the Properties button.
  5. Double-click on "Internet Protocol (TCP/IP)" and make sure both radio buttons are set to "Obtain...automatically".
  6. Close all Windows by clicking "OK". (The second one takes a moment, because it applies the settings.)
  7. In the open window choose the Support tab and you should see your IP address, your Default Gateway (192.168.1.1) and your DHCP server (192.168.1.1)
For your wi-fi setup, repeat step 2 through 7. In step 3 you should see your "Wireless Network Connection". Use this one and repeat the remaining steps.
If this did not fix it for you, you have to come back and give more information on:
  1. Which router model are you using?
  2. What computer do you have?
  3. Which operating system (Windows, Linux, Mac)?
Let me know how this worked for you and I'm happy to assist further.
Jan 14, 2009 | Compaq Presario C700T Notebook
Cannot connect to internet thru ethernet jack on computer
It could be. Check your Device Manager and make sure the device isn't disabled. Also each adapter has its own TCP/IP settings so make sure yours on your ethernet adapter are set the same as your USB adapter that is working. If it does turn out to be bad you can always add a new ethernet card for cheap.
Jan 05, 2009 | Dell Dimension E521 (D10E16) PC Desktop
Please Help! My IP is driving me crazy!
modem only transmits signal.
router talks to your provider and gets IP address from them, depending on your subscription, you may have a static or dynamic IP.
your computer gets internal (home network) IP from the router, you don't have to worry about that since it is the router's IP address that is seen on the internet (router splits / shares a single internet connection in home networks).
about wireless connection from computers/wi-fi gadgets to the router, must configure the router with the ff:
wireless network name (aka SSID)
security type (WPA/WEP) and password/passphrase/security key
channel (1-12)
the above info must be then set to the connecting computers/gadgets
about wired connection: a working ethernet cable (looks like a phone cord but fatter) and a working computer/gadget ethernet port.
Wii will work - check Wii's website for connectivity options / instructions.
Dec 18, 2008 | NetGear WGR614 Router
Blank Screen
I would verify what the firrmware is of the phone. It is possible that the phones need to be upgraded.
Mar 27, 2008 | Avaya 5610 IP Phone
Problems with IP address
Possible three (3) solutions:
1. Purchase and install a PCI LAN card (NIC) inside your "old tower". Should not be that difficult using any available PCI slot. Most would be auto detect/install by Windows (XP) or should come with a driver CD;
2. Use a USB to Ethernet adapter/converter; and/or
3. Use static IP address for the tower Same IP add (+1 on the last digit, same Subnet Mask, Default Gateway and DNS (if any). Should you need additional information on this method you need to post back details of your modem (brand/model, normally in a sticker underneath) so we can determine if it will allow simultaneous connection on USB & LAN.
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Jan 24, 2008 | Linksys Wireless-G WRT54G Router
Pls. help
When dealing with a router there are multiple IP address scenarios, on the internet service provider's (ISP) side you can have either a static or dynamic IP address. I believe most routers by default are set to accept a dynamic IP address from the ISP. Where the ISP permits the router can also assign IP addresses to each device that attaches to it allowing a single ISP connection to be shared by multiple computers. This is also generally the default for routers purchased for home use and the wireless adapters also accept the dynamic IP assignment from the Router. With the logical discussion out of the way I believe you wish to discuss the physical connections to be established. Again this is a generic discussion not knowing your specific environment. port types - I will refer to phone ports (technically RJ-11 either two or 4 wires (these cables plug snugly into phone jacks and modem connectors) and ethernet ports (technically RJ-45 which are 8 wires and to big to fit in phone and modem ports) First you have a connection provided by the ISP for DSL this is your phone line where filters are attached to your voice phones and an unfiltered phone connection goes into the DSL modem's phone port often with an ethernet port. If you have cable generally the cable company provides a connection to a cable modem which has an ethernet or other port to connect to your system. The ethernet port generally connects to the wan port (generally separate) of your wrt54g router with an ethernet cable. Computers can be attached to the wrt54g router using the 4 ethernet ports in a group provided they have an ethernet port too. Wireless cards connect to the wrt54g router through radio waves and with antennas on the router and often internal to the wireless adapter (often embedded in a notebook computer today). These details are enclosed with your ISP's instructions and the Linksys router instructions often with pictures to help the explanation.
see
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1149562300349
if you do not have the user manual.
Nov 30, 2007 | ASUS AAM6010EV Router
Avaya 5610 IP Phone Logo
290 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
