I PLUG IN THE AC AND IT MAKES THE BEEPING SOUND WHEN I TRY TO HIT THE POWER BUTTON IT WON'T TURN ON.LAST YEAR I HAD TO PRESS THE POWER BUTTON SEVERAL TIMES UNTIL IT WOULD CATCH AND THE AC WOULD TURN ON.BUT ONCE I TURNED IT OF I WOULD HAVE TO GO THRU THE SAME PROCESS UNPLUG & PLUG WHILE PRSSING THE POWER BUTTON UNTIL IT TURNED ON.SO I FIGURED IT WAS THE MEMBRANE SWITCH CHANGED IT AND NOTHING.I PLUG IT IN IT BEEPS TO BE READY TO TURN ON I PRESS THE POWER BOTTON AND NOTHING.I LOST THE REMOTE TO THIS SYSTEM ABOUT 3 YRS AGO. PLEASE HELP ME I HAVE 2 SPECIAL NEEDS CHILDREN WHO REQUIRE A/C,SINGLE MOM AND CAN'T AFFORD A TECH AT THE HOUSE,TH A/C IS 2002.
    Champion:
  • 233 Answers
I assume that it has a control board in it, it could be the connections on the board or the board itself. This is really not a do it yourself job, and the board may be a problem to source, if you already changed the switch then you should be able to tackle it, the board should be available online but I would recommend that you have a tech do it... if you do choose to give it shot then please be careful and mark the wires as you pull them off, be sure the power is off before doing anything, and be aware of the capacitor as it stores power even with the unit off, and can be very dangerous. Good luck
Posted on Jul 14, 2009
My lenovo g575 won't power on at all tries then shutdown a few seconds after I hit power button
Try this, and let me know if it works.
  1. First unplug the AC adapter.
  2. Next remove the battery.
  3. Then press the power button 11 times, and hold it for 30 seconds on the 11th time
  4. Reinstall the battery.
  5. Finally plug the AC back in.
  6. Turn on the Laptop
Feb 17, 2015 | Lenovo Computers & Internet
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Hp altec lansing makes a beeping sound while starting
Try running a registry cleaning program. That should sort the errors out
May 20, 2014 | Acer Computers & Internet
My automatic headlights won't turn off on my peugeot 206 2.0 hdi (2001) any idea's?
yes put key inignition turn to first turn at the end of the indicator stalk there is a button press and hold in until it displays and makes beeping sound same scenario to turn back on
Mar 17, 2013 | Peugeot 206 Cars & Trucks
My sony vaio won't turn on
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
When i turn my syncmaster 2233 computer, it turns on but it makes a beeping sound alot of times and it won't stop.. I usually fix it by turning the power cable on and off and it will stop the beeping...
Remove the memory (RAM). Clean its contact points by an eraser. Fix it. If it does not work, try using another slot. If it still does not work,replace it with new.
sonsunny
Jun 14, 2011 | Computers & Internet
My friends computer just stopped working while she was using it. The screen froze and than she shut it down. When she tried to turn it back on all that happened was that the caps lock, the scroll, and the...
There are a number of things that can cause this to happen. Try taking the battery out of the notebook, disconnect the AC adaptor (if in use) press the power button a few times. Re-install the battery, reconnect the AC (if needed), press and hold the power button for about 2 seconds. This is a hard reboot and should correct you issue. When the notebook powers up, make sure you remove any cd's in the cd-rom drive.
Good Luck,
C2Solutions
Jan 05, 2010 | HP Compaq Presario V2000 Notebook
Help
go to sharpusa.com and click on support, they have all the model airconditioners and all the help. its in pdf format and i dont know how to paste the info. really easy problem to fix.
Basically, tells you to make sure air filter is clean.Unplug from wall, then hold Power/on/off button down and plug unit in wall. press Power/on/off button until you hear a beeping sound(approx 5 sec) then disconnect powerplug from wall. plug back in and start your ac again. it should work!
If this dont work try the same thing but by pressing the Mode button and same kind of operation as above, but the unit will start to operate after you press mode and herar the beeps. turn off by pressing On/off button. then start as normal. if you cant get it go visit the website.
Jul 16, 2008 | Sharp ENERGY STAR AF-S60FX...
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
