Question about Refrigerators
My ice maker is not working well as expected. I
My ice maker is not working well as expected. I feel it may be the water supply. Where is the water filter located on those refrigerators? I use well water.
  • 43 Answers
Check for kinked water line coming from wall and just inside the rear lower panel of the fridge
Posted on Jul 13, 2009
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
Amana refrigerator model th121tw ice cube maker is not freezing. It freeezes some ice cubes but accumulates water in the tray below
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Refrigerators
Water supply tube keeps freezing off water supply.
its hard to tell but most likely the valve is not closing all the way. but it could be the ice maker calling for too much.... www.whirlpoolpartssurplus.com
Jun 23, 2009 | Frigidaire FRS3R5EMB Side by Side...
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Apr 13, 2009 | Refrigerators
Ice maker only makes cubes. It will not make crushed ice.
Hi
Kindly check it could be because of following reasons :
  • Freezer may not be cold enough.
    Temperature must be 5 degrees (Fahrenheit) or colder to work properly.
  • Normal ice making capacity.
    The ice maker will produce between 2.5 to 4.0 pounds of ice a day depending on your model. Side-by-side models come with a large ice bucket and it may take up to three days to fill this container.
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
    Please feel free to contact for further assistance
    Thanks
    Rylee
  • Jan 24, 2009 | Maytag MSD2651 HE Side by Side...
    Ice maker
    Check supply tube to see if frozen or blocked using Q-tip or feel to see if frozen. if Frozen, hold up clear glass with heated water placing tube in hot water. Hold till ice in tube melts. Clear glass will allow you see ice slip out.
    Jan 19, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
    Whirlpool GS6SHAXMQ Side by Side Refrigerator - Ice Maker Problem
    This happened to me after i had to move the freezer and it was unplugged for a while. When it was plugged back in the ice maker would not work.
    Assuming both the ice maker itself and the rear water AC solenoid switch are actually not broken and are functional, and you are getting water from front door dispenser, then check the inside supply tube (black) is not frozen and blocked. Check with q-tip or feel to see if frozen.
    If supply tube is frozen, thaw by holding up small full clear glass of heated water placing the frozen tube into the heated water. The clear glass will allow you to see when ice slips out.
    Next try resetting the freeze cycle. Turn off the ice maker switch, remove the maker by carefully disconnecting the inside power cord. You will need to remove the inside door flap. Rinse the maker with warm water, allow to come to room temp.
    Re-install maker, connect power cord. Turn on ice maker switch. Make sure Infrared sensor is not blocked. Now wait for temp change and listen for water to fill tray. It took maybe ten minutes for me. You will be able to hear the water fill with the door closed.
    Again, this assumes nothing is actually broken.
    This worked for me. Good luck.
    Jan 18, 2009 | Whirlpool GS6SHAXMQ Side by Side...
    Ice maker not making ice, model KSR125F
    one of fours things can be wrong,first make sure it's on,second remove the supply tube in the freezer and look to see if it is frozen, thaw with hair dryer,third the water inlet valve has failed,fourth the icemaker itself is bad,put your hand in the ice maker well to see if you feel water if you do the water inlet valve is working and the icemaker itself has failed if you don't feel any water the water inlet valve has failed,let me know,thanks-mike
    Jun 23, 2008 | Refrigerators
    Whirlpool GS6SHEXNL not making ice
    To start let's make sure that the wire we lift to stop the ice when that bucket is full, is in the down position. Now we can concentrate on two possible problems, one the water supply, two the ice maker itself. If you dip your finger in the ice maker, and it's dry then it's a water supply problem. This can be as simple as a kinked supply tube, a bad solenoid (to find it follow water line). It could also be the mechanics in the maker that control the solenoid are stuck or broken, in that case a new maker is needed. Before we go on, make sure the maker's is fully plugged in for power, and if you know how, check to see if the socket, it plugs in, has power. If we have power and you feel hard cubes in the maker ready to be pushed out, then the problem is in the maker itself and will probably need replacement.
    hope this helps
    Dec 13, 2007 | Whirlpool GS6SHEXNL Side by Side...
    Refrigerators Logo
    44 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
