Question about Ruud Heating & Cooling
How do I charge/ add freon to my RUUD Acheiver SEER 10? Also, what other annual maintenance would I be able to do by myself?
  • sgrass0604 Jul 16, 2009
    Nope - won't shoot the messenger. Thanks for the info - very helpful.
    Scholar:
  • 91 Answers
There are quite a few things you can do to keep your unit in good shape. Most of which is keeping it clean. You can use a household sprayer to clean your coils. Pros use a commercial cleaner made for this purpose, but I have success using proucts like 409 and simple green. To clean the coils , turn electric off to unit, spray coils, you really have to saturate them well, let solution do its work...then rinse very well, load up sprayer a couple times to rinse, let unit dry then reconnect. Now for the other part you asked about.Now don't treat me like the enemy or anything, but by law (section 608 EPA) you have to get someone EPA certified to refill, take out refrigerant. If you're unit uses R22 refrigerant it may be a bit costly, like the auto refrigerant being discontinued a decade ago, now the home stuff is no longer produced causing the price to skyrocket. Please don't shoot me the messenger, but you have to call somebody reputable to do this portion. Good luck
Posted on Jul 13, 2009
I have 2 seperate Achiever AC-seer 10 units installed 6 yrs ago. One cools downstairs, the other upstairs. I have never used them before. They have been exposed to heavy snowstorms over the years in...
No Freon doesnt evaporate the only way you have to charge an A/C unit is if it has a leak somewhere in the system. It sounds like your compressor is locked up I would try installing a super boost to the Condenser (outside unit). Let me know
Jul 26, 2011 | Ruud Matching Split Air Conditioner
I have a 12 year old ruud a/c system for a 1500 square foot house. I can not read the tag on the unit. looking for the pressures, type of freon and what the vent temperature should be. I can make out a...
Ruud back then had a label tag that would fade out or fall off, the ref is R-22, if you check the supply air temp. and then check to return air temp. the difference is plus or minus 20 degrees (18 to 20pluss ) your good, its called delta t. 20 degrees is good. The 10 is the SEER rating.
Jul 05, 2011 | Heating & Cooling
I had Ruud heating and cooling installed five years ago. Last summer my electric bill doubled when I began running my air conditioner. It did not do that the first few years that we were in this house. ...
Hello In a way you are stuck with what is called a S.E.E.R. rating which is a statement of efficiency from the manufacturer.Ex: a 10seer is less electricity to run than a 14 seer.The model # would have told me the seer rating.A 4 ton `1 zone is a large unit but even a 10 seer 4 ton is never cost prohibitive to operate and Never doubles the electric bill in 5 days out of thirty.Is the home unoccupied all month and you use it on weekends?Did the neighbor run a strange wire to your property?There might be stray or lost voltage in rare cases if there is poor grounding issues.Has the unit been serviced? A low freon charge will cause a unit to run excessively long and not cool.Do you run the indoor blower all the time.Has there been any other major purchases made (at all) that you plug in?I would look at everything because there is some cause for DOUBLE bill amount not just the cooling bill.Good luck
Jun 18, 2011 | Ruud Heating & Cooling
MY AIR CONDITIONER RUUD ACHEIVER 80 IS FREEZING UP
Hello Sheri Turn the thermostat off BUT the fan switch ON/AUTO to the ON setting this will speed defrost time give it 3 hours.Replace the air filter.Was it clogged?Is any thing at all blocking the intake grille?Poor air flow is a cause of ice.Turn it back on and see if it freezes up again.If so, have the freon level checked it might need a recharge.If not a bad/neglected filter will do it every time.
Jul 26, 2010 | Ruud UAKA042 Air Conditioner
Have tempstar model NFCX3600CZ Ser# L0239 58594 and unit will not switch from head mode to cool mode. Contractor says it's a bad reversing valve. cost will be $525 to fix. Question estimate.
I am a Technician myself and work for myself. Their price is fine if they don't try to add as they go. Reversing valves are delicate to install and you have the issue of recovery and disposal of the freon that was inside your unit. I am not siding with the Technicians either there are good ones and bad ones. Did this technician come out and test the unit or was this a quote on the phone? Depending on the age of your heat pump I would consider other factors. We also are nearing the end of the R-22 age and moving to better more efficient units that conserve energy. SEER rating means a lot if you add the cost of energy. The newer styles of heat pumps work under extreme pressure. The higher the seer number the lower the cost for energy. Your model may be a 10 seer I will look after I finish this post. Let me know the age of your heat pump. Remember a heat pump works all year round and not just summer months so life span is reduced. Thanks, Sea Breeze
May 16, 2010 | Ruud Central System Air Conditioner
Looking for a Ruud 10 SEER condenser cabinet to replace
nope ive been down that road nothing new try one of your local contractors they may have some thing used for cheap. Tom
Jun 28, 2009 | Heating & Cooling
Rudd 10 seer
same as appldoctom but you need to braze the lines do not sweat them
Jan 31, 2009 | Ruud UBHC Air Conditioner
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
166 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
