HOME ROW KEYS NOT WORKING PROPERLY
IF YOU PUSH J WHAT APPEARS IS JM
    Sergeant:
  • 239 Answers
Clean the keyboard properly...keys might have stuck...since j and m near .....both the keys might be contact..if possible remove the keys and place it again..
Posted on Jul 13, 2009
Hi there, i have microsoft office home and student 2007 on windows 7 and need the product key to stop it from asking me every time i use it. your help would be very welcomed, many thanks Matt.
Home and Student 2007 S/N: HBC66-D6YR7-CRP7H-T8VP4-99PMW ----just find me on facebook maroo lumongsod comments about this serial key: Raj 2010-01-18 Superb!!!!! the key worked for me..... great work guys.. keep it up jm 2010-01-28 salamat gyud!kagaling na gamit ku tu! RAUL BEAZ 2010-02-16 MY FRIEND YOU ARE GOOD! DAM Ady 2010-03-16 Finally... a product key that worked!! Kingsley aka decentk 2010-03-24 While am about 2 use it, i pray its works thkz Kingsley aka decentk 2010-03-24 While am about 2 use it, i pray its works thkz Kingsley aka decentk 2010-03-24 While am about 2 use it, i pray its works thkz AYå?¾E
Jun 27, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have a studio 1749 my problem started after i removed the keyboard to clean it because of the dusty enviroment i work in. After putting the board back in i noticed the entire 2 bottom rows of keys didnt...
it's more likely you haven't put the ribbon cable back properly. try removing the keyboard again and reinsert the ribbon cable carefully - remeber there is a bable grip that needs to opened to remove the cable and closed again after insertion to maintain contact
Apr 11, 2011 | Dell Studio 17 (1749) Laptop black -...
The # 4 key is seems to be messed up or sticking, when I push other keys #4 shows up behind the key I pushed, sometimes the fours keep going across the screen
Here are some diagnostics you can perform. If the tests fail then the calculator needs to be repaired.
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Jul 26, 2010 | HP 48gx Calculator
My home row keys (and only those 8) do not work.
Unfortunately, this is most likely a bad keyboard and the keyboard will need to be replaced. In the meantime, you can use a USB keyboard in its place.
Aug 21, 2009 | Dell Inspiron E1505 Notebook
Calc. asks to recover memory, display goes blank, keys beep
The following procedure valid for the HP 48G should work for the HP48GX.
Self test.
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
Hope it helps.
Aug 04, 2009 | HP 48gx Calculator
I HAVE INSPIRON E1405. HOME KEYS ARE NOT WORKING
First boot to the Utility partition and run diagnostics on the keyboard (Fn Power button) see if they keys work correctly in the Dell Diagnostics keyboard test. If they do not, then either the keyboard or the motherboard is bad and I'd replace the keyboard first.
If the keyboard functions normally in the DIAGs, then the issue is most likely the regional and language settings in CONTROL Panel
Jul 13, 2009 | Dell Computers & Internet
The last row of icons on my iphone won;t work. Help....
The last row of icons which is the bottom row with Phone iPod etc?
It sounds as though your digitizer is bad, the iphone digitizer is delicate and seems often goes bad.
does your unlock screen work?
the bottom off the screen handles the unlock and bottom icons.
if your unlock switch works then you may just have a software problem going on.
reboot your phone by pressing and holding the power and home buttons until the apple appears.
when it reboots see if it works properly, if not you may have a bad digitizer.
is your iphone a 2G or a 3G?
Jun 03, 2009 | Apple iPhone Smartphone
How do you turn up the brightness on a hyosung laptop
Push the 'f'n' key while pushing the brightness up key at the same time. The brightness key is usually accross the top row of numbers F6 or F7.
Jul 22, 2008 | Computers & Internet
Imation superdisk drive
imation super disk SD-USB-M2.Solution to run under Vista service pack 1.Works for me
boot up your puter then plug in the imation super disk into your puter's usb port then into your power sulpply socket.Then if you have a reset button on your puter Press it
the puter then shuts down and resets itself when the screen appears it asks "Start up normally" Press enter.The drive is recognised and works.Its a bit of a ball ache but works for me.Hope this helps others with the same problem
JM.
Jul 12, 2008 | Imation (01946) External Floppy Drive
Computers & Internet Logo
839 people viewed this question
David Payne
David Payne
