Question about Apple iPhone Smartphone
Ok i activated my phone right and i put my sim
Ok i activated my phone right and i put my sim card in and my battery and my phone still say insert sim why is it doin that
  • 63 Answers
May be your sim card demaged...
Posted on Jul 13, 2009
Nokia1209 insert sim
i think when you inserted a sim it is asking insert sim right?
for temporary first insert the sim card ,insert battery then put a small paper. fold it and put it ...if this doesnt works contact a repair shop
Sep 22, 2012 | Nokia 1209 Cell Phone
Tip
Unlock codes for Samsung Sgh J700i
<span>1- Power on phone, type : *#7465625#<br />you will identify which code is active , which is inactive. <br /><br />2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone you must see " insert sim" not "invalid sim.." <br /><br />3- Type : *2767*3855# <br />your phone should restart after 1 min,<br />now, and before it restarts, push your sim card in, without removing battery. <br /><br />4- Your phone should work and accept the sim card ,, but if you chek locks you will find that your phone is still locked <br /><br />5- Now type : *7465685*638*00000000*00000000#<br />your UNLOCK CODE is 00000000 now , Enjoy <br /><br />6- Now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :<br /><br />* Disables CP lock : #7465625*27*00000000#<br />* Disables Network lock : #7465625*638*00000000#<br />* Disables SIM lock : #7465625*746*00000000#<br />* Disables SP lock : #7465625*77*00000000#<br />* Disables Subset lock : #7465625*782*00000000#</span>
on Dec 25, 2010 | Cell Phones
Tip
How to Unblock Network lock of SAMSUNG SGH-J700
SAMSUNG SGH-J700 UNLOCKING:
1- Power on pone ,, type : *#7465625#
2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on pone ,, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your pone should restart after 1 min ,,
now ,, and before it restart , push your sim card ,,without removing battery
4- your pone should work and accept the sim card ,, but if you check locks you will find that your pone is still Locked
5- now type : *7465685*638*00000000*00000000#
6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,Here details :
on Jan 21, 2010 | Cell Phones
How can i put sim card on my cellphone
the back of your phone and under the battry and bam there it is put your sim card right in the sim card hole
Apr 14, 2012 | LG enV3 VX9200 Cell Phone
Sir good day, I have a motorola BC 60 mobile phone. And my problem is. it is in no service the whole day.... can you give me possible reasons and solution for this. Thank you
BC-60 is not your mobile's model. It is the battery's model no. Probably you don't yet inserted the SIM/RIM card to the phone. Open the back cover then remove the battery and u will find a SIM/RIM card slot. Insert that as per instruction then connect battery as per and switch on the phone. You should get the service if the sim card is active. Ok..
Nov 05, 2010 | Cell Phones
Sim card not working with my ic 902 phone.
try to reformat the sim before inserting it in phone. also make shure to not exceed sim memory size or speed.
May 04, 2009 | Motorola Mobility ic902 Cellular Phone
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Insert simcard nokia 7200
hi the only one thing you can try without replacing the sim card reader is do you know when you put the simcard in if you push on the simcard with your finger so your pushing it down onto the contacts is fold up some paper so that it put pressure onto the simcard when you put the battery on as alot of times the contacts dont touch the sim card properly so putting some folded paper on top of sim card pushes it down onto the contacts properly.
This solves the problem in most cases but it can be difficult to get right as if the paper isnt thick enough then it might not push it down hard enough to make contact.
If after doing this it still dont work then this either means the sim cards no good but you could try it in another phone or it could be that the sim card reader is not connecting with the board properly and would need replacing.
Make sure you check the contacts are clean on the sim card and the sim card reader to make sure this isnt problem.
If you have not tried the sim card in a different phone then it could be the sim card is no good.
Did this sim work in the phone before just in case the phone dont accept that network as you can get this message if this is the case.
Let me know how you get on and if you need further assistance ok
Apr 08, 2008 | Nokia N95 Cellular Phone
Insert sim card message
i got problem with my phone n-gage,after i turned my n-gage on..itssays "insert sim car"..i already put my sim card inside of it
Mar 01, 2007 | Nokia N-Gage QD Console
Apple iPhone Smartphone Logo
93 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
