Question about Kirby G5 Bagged Upright Vacuum
My Kirby G5 has a power problem. Its handle needs to be tiltled all the way to almost flat position for the power to comne on. If the handle is back up to its standing postion, the power will be off. What's the cause of this problem? Any suggestions/comments will be greatly appreciated!!!
    Problem Solver:
  • 19 Answers
Sounds like u may have a problem with the cord connection inside the power plant would suggest u take to repair shop not something i would suggest u try yourself
Posted on Jul 15, 2009
G3 vacuum handle spring replace video kirby
see utube for fitting. however i suggest you get your local kirby enginere to do this
Jan 07, 2013 | Kirby G5 Bagged Upright Vacuum
I have a Kirby G5 and need to replace the gear drive shaft, as the lever inside fell off and the shaft came out. (Common problem by the sound of it.) How do i remove the actual gearbox itself. I have...
I have never touched a Kirby vacuum before and my wife had the same issue. The neutral/drive pedal just fell out so I figured I would give it a shot to see if I could fix it and quickly figured out the 3 screws in the bottom plate for the drive unit wasn't the answer.
I was able to figure things out out after I found a parts list with diagrams at the follow web site and address:
Vac Parts Warehouse.com
http://www.vacpartswarehouse.com/category-s/2821.htm
The two parts involved are:
13. Bracket Cam Assembly Neutral Drive Pedal 557689A
16. Kirby Pedal Cam For Neutral Drive G6 558499A
Here's how to get to a point that you can get these two parts in/out of the machine.
- Remove bag and fill tube from handle and main unit
- Remove floor nozzle assembly
- Remove the handle via the two screws at the handle fork plate (these have loctite on them so needed a socket wrench with torex bits to get them out).
- Remove the plastic rear scuff plate vie the screw with the power cord anchor and screw by the Pedal Cam For Neutral Drive. Note release plastic tab in slot in the center and lift from the back and then over the base where the handle attaches.
I did not do this as I removed the the power drive assembly so I could figure out how to put the dive assembly back together. The pressed on arm that drives the cam assembly had pulled of the pedal shaft so this also made it easier to fish out the parts and experiment on positioning the arm in the right spot . I found the arm and a spring washer inside.
I assume at this point you could loosen the screw (don't remove it, it's the only one with a star lock washer on it) on the bottom plate that attaches the Bracket Cam Assembly and slide the Pedal Cam out and a new one in if you can get the part and replace it. The part was 16. Kirby Pedal Cam For Neutral Drive G6 558499A at Vac Parts Warehouse.com. The one listed on the website said it was for a G6 even though the parts listing is for a G5 so I don't know....
To continue to disassemble and take the power drive assembly out:
- Remove the 4 screws from the Cover Shell assembly - the metal top part. You do not need to remove the hinged Headlight Cap that is attached to it.
- Remove the 4 screw from the bracket assembly that has the handle attachment and forward/reverse switch. It attached by two wires. I only disconnect one and swung it to the side.
- Snap off the the on/off switch and disconnect from the Actuating Rod Foot Pedal to Power Switch.
- Remove the 3 screw from the bottom plate of the power drive assembly.
- Remove the drive belt.
- The power drive assembly will now drop out the bottom.
I just put the spring washer and arm back on the shaft and reassembled. I'll see how long that lasts before before buying the new part.
Have fun.
Aug 08, 2010 | Kirby G5 Bagged Upright Vacuum
My Kirby G5 will not start. Head not aligned?
Check the positioning of the roller (it's got numbers 1 2 3 at each end, make sure it's on the same number at both ends).
Just a thought too - check your power lead at the machine end as due to the age it may have deteriorated and the wire inside may be broken.
May 21, 2010 | Kirby G5 Bagged Upright Vacuum
My Kirby G5 has stopped working, last few times it was used it kept cutting out everytime the handle was moved??????????
This definitely sounds like your cord is bad. The reason that I specifically think that it's your cord is because the cord is actually connected into the handle, and is attached to the handle in the back. This would make sense why the machine was cutting off every time the handle was moved.
Also the cords are notorious on Kirby's for going bad, and are usually the only thing that goes bad on a constant basis.
Here's how you can check to see if your cord is bad or not:
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums2_bing.gif I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
GoVacuum.com
Apr 14, 2010 | Kirby G5 Bagged Upright Vacuum
When the power assistance drive to my G5 is engaged it is fixed in reverse.
I know the problem is not the tec-drive, it is the position on the handle piviot spring assy. no parts should be required to fix this issue. However a vacuum repair shop will be needed for this problem. I would find one that offers free estimates. might save ya some money.
Nov 18, 2009 | Kirby G5 Bagged Upright Vacuum
I bought a kirby g5 with no manual and can't figure out how to clean the couches with it!!!! help!!!!!
you can turn your Kirby into a handheld by removing the handle (button down on the bottom) if it came with all the attachments. Take the big handle off attach the small one onto it and you can take it and clean your couches, bed, stairs, etc. had mine for twelve years never had a problem with it.
Jun 10, 2009 | Kirby G5 Bagged Upright Vacuum
I have a Kirby G5 vacuum that when light pressure is put on the handle it moves forward but in a jerky movement. Like the drive is engaging and disengaging. If you keep forward pressure on the handle the...
I hope adjusting position of the position of the "pivot spring assembly" will help. but you may have to disassemble entire slide assembly to clean it up if it still does not work smoothly. See instructions HERE (adjustment is explained in step #6). Try to "play" with screws #4 and if it does not help - clean slid.
Good Luck
Feb 28, 2009 | Kirby G5 Bagged Upright Vacuum
G5 Kirby drive problem
Gary...
You need to adjust your transmission. Here's a link that may help...
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 intermittent power
I would say that it is a short in the power cord.
Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions, parts (cords too!!) and free repair guides!
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Jul 31, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
89 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
