You need to replace both of the convergence IC's and any bad resistors around them that protect them from damaging the power supply.
This repair can usually be done in the home and takes about an hour; I have done hundreds of them and now is a slow time of year for TV shops; look around if you are not able to do this repair; you can buy the chips on Ebay for less than 15 dollars for a pair plus shipping.
This is a very common problem in projection sets.
If this has helped you give me a vote here as I do this for free. If you have questions or need help:
Just to clarify, it sounds like what you are saying is that the image
appears to duplicate in either red or blue along the edges of the image
(especially white lettering and probably increasing along the boarder
of the TV). This is resolved by converging your TV. Convergence will
drift normally on large screen projection TV's over time or through
moving them. The Hitachi 57f500a has a feature called "Magic Focus" (pg
36 in your manual) which will auto converge the image. If the auto
converge feature doesn't work, on page 37 in your manual, it explains
how to converge manually. If you do not have the manual, I have the
image of the pages below. If for some reason this doesn't work, please
provide additional info and detailed prior to rating the help.
Your convergence chips are bad. You can set a repair kit from www.TvRepairKits.com for your model. Their kits come with all the parts and a complete photo instruction guide.
First try going into the customer menu of the TV. Look for the convergence alignment parameter and see if you can move the images back into place.
If you can't move the images back together, this is a failure of the convergence circuit in the TV. The convergence output ICs will need replacement and the TV should then be re-aligned. Look for a service center that is factory authorized. Expect to spend $350-$500 to have this issue resolved.
