Question about Sea and Sea MOTORMARINE II-EX 35mm Point and Shoot Camera
I have a 20 hp Johnson 20R71S and when I am in forward gear and the boat is close to full throttle it seams like the gear shift is coming in and out of gear for a split second, this happens every time I take off and the gear selecter is in forward. Would this be a problem with the clutch dog? Mike
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Johnson 7.5 hp 1956 model AD-10M shifter wont go into forward
only guessing but sounds like the connecter came apart halfway down the lowerunit open it and see
Jun 12, 2014 | Boating
I have a 1973 Johnson 40hp outboard motor that will not shift into forward gear. It will only go in reverse
Does it jump in and out of gear,if so,clutch dog and forward gear need replacing
Apr 02, 2014 | Boating
150 johnson wont idle wot great
start engine while in water with slightly high tickover , remove throttle cable and find throttle stop screw and adjust till 800rpm holding the throttle arm against the stop and see if you can select forward gear without stalling ! depends what size pitch prop your using as you mite need tickover slightly higher but as long as it selects without stalling then ok ! as long as it doesnt jump forward , in gear should be 800rpm + or - 100 max ! if still stalling then possible requires fuel system cleaning !
Jun 03, 2012 | Light Outboard Motor Boat Bass Fishing...
I need to find out how to adjust my shifting linkage for a 1988 mercury mariner 60 hp. i don't have a diagram
Its not too bad to adjust, just takes patience and an assistant would be nice. You want to center the linkage in neutral so the throttle does not move immediately when you shift.
This can be adjusted with the motor off. You need to try it first by putting the Handshift in neutral and spinning the prop by hand. The prop should spin without locking into gear or making a "ticking noise" with the gears partially meshing. If there is a "ticking noise" you need to disconnect the shift cable; adjust it until the noise is gone. Then reattach it.
Now have your assistant move the Hand Throttle slightly forward, the gears should make a "ticking sound" before the throttle cable moves, and the gears should lock into forward before the throttle cable moves. If the Throttle cable moves too soon, you want to disconnect the Throttle cable and turn the knurled fitting to return the Throttle cable to a closed position. Easy does it with these adjustments.
If you go too far while adjusting the Forward gear it can show up on Reverse. But remember, you do not need much Throttle in the Reverse gear. Reverse is only for manuvering at slow speeds. You want low RPM for Trolling in Forward so you want a little slack in the Throttle in Forward gear.
Jul 17, 2010 | Boating
35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Aug 22, 2009 | Boating
Shifter jumps out of forward gear on 64 9 1/2 hp Johnson motor
sound like the shift fork, or fwd gear is damaged in the lower unit.....special tools are required for this repair .....if you got them cool, if not seek a shop for further assistance.......hope this helped...GL
Jul 03, 2009 | Boating
Outboard boat engine shifting problems
Check for a lose or sloppy shift linkage.
Mar 30, 2009 | Boating
Sea and Sea MOTORMARINE II-EX 35mm Point and Shoot Camera Logo
135 people viewed this question
Top Sea and Sea Cameras Experts
Are you a Sea and Sea Camera Expert? Answer questions, earn points and help others
