Question about Cameras
Ryobi tek4 camera takes pink pictures and pictures look grainy. Anything white turns out bright pink in photo. Flash memory was reformatted to try and solve problem. Nothing improved. Camera is new. Is it defective or is a setting off?
You have to go to Menu and set up the Scene Mode as "Night Portrait" instead of "Default". Unfortunately you will have to do this every time you turn the camera off since it does not remember the change
Posted on Jul 16, 2010
My kodak easyshare cx7430 camera has pink in my pictures, how do I get that out?
follow this steps and fix it. God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000003236 StartFragment:0000000502 EndFragment:0000003219
1. The batteries may need replacement. Somedigital cameras continue to function when their battery power is low, but produce grainy photos with incorrect coloration. Make sure you aren't using Ni-Cd rechargeable batteries, which are generally not recommended for cameras.
2. For the best picture quality, make sure the camera is set to its highest resolution. This may have been adjusted by accident. The process for doing this varies greatly among different digital cameras. Keep in mind that fewer photos will fit in the camera's memory and it will probably take longer to transfer them to the computer, at a higher resolution.
3. Digital
photography tends to be more prone to blurring (caused by slight movement of the camera while the photo is taken) than 35mm film, especially with very small or lightweight digital cameras. To remedy this, try using a tripod and/or the camera's timer, if it has one. Adjust the camera's shutter speed if possible.
4. If colors are too pale, using an image editing/viewing program (such as PictureWorks MediaCenter) to increase the Saturation level may be helpful. If the camera has produced colors which are entirely wrong (everything is in shades of black and purple, for example), you can turn the saturation all the way down so that it becomes a black & white photo.
5. The lens may need cleaning. Make sure you use a cleaning material which will not scratch the lens. If possible, refer to its manual for specific cleaning instructions
Jan 30, 2013 | Kodak EasyShare CX7430 Digital Camera
All of the pictures are grainy and very dark- not usable camera at all- less than 2 years old I have re formatted the SD card, changed the batteries, and reset the camera to default settings
To fix your issue with the Canon Powershot SX110 IS Digital Camera, try cleaning the lens. A huge issue with malfunctioning pictures can be as objective as a dirty lens. If that doesn't solve the issue, try to make sure that your flash is working to its full power. If you are taking a picture in a low-light area and the flash isn't giving off a strong enough light, this will cause grainy/noisy dark photos. Lastly, try playing around the with settings on the configuration screen. Sometimes digital cameras can malfunction, even after reformatting, and will apply alternate settings from what you originally had set.
Hope this helps!
-Anonymity
Feb 24, 2011 | Canon PowerShot SX110 IS Digital Camera
Grainy pictures
If you are taking pictures in low-lighting conditions without flash, then the pictures will appear grainy. Set the ISO to a lower number (try ISO-100 to start with) and use the flash to compensate for low-light conditions.
This should improve the grainy appearance of your photos.
Dec 29, 2010 | Nikon D100 Digital Camera
Pictures that I take come out very white/bright. you cannot tell details. I have changed batteries and have the setting on auto.
Double-check your flash settings. You mentioned the camera is in Auto mode, but the flash has separate settings from the camera's shooting mode. With the camera in shooting mode AUTO check the Flash settings (Auto, Red-Eye Reduction, Fill-In, Off) It may be set to 'fill' causing your photos to be too bright.
Also, depending on how close you are to your subject the flash may not be needed. Using the flash when too close to your subject (less then 3 ft.) will cause bright/white photos. Turn the flash OFF if you are taking macro or photos closer then 3ft.
If neither of these fix your problem, turn the flash mode OFF, and camera shooting mode to AUTO and in a naturally well lit area, take a photo, if the photo is still too bright, you may have something mechanically wrong with your camera.
Nov 03, 2009 | Olympus FE-210 Digital Camera
When taking pictures outside bright white photos
i am an train picture guy but neverthe less u cant take anything for granted put cam on "P" and see whad happens and check your manual
Aug 24, 2009 | Olympus FE-220 Digital Camera
I have a brand new Finepix S8100fd camera and the majority of the photos are speckled no matter what setting I use. However the super macro setting rocks and pictures are super clear! My Fuji 7.1 mega
Common issue with the A8100fd. The most likely problem you are having is not enough light. Try shooting in bright sunlight to test the "graininess". Make sure you use the flash anytime the light is not bright. Even though the camera will shoot in low light (without flash), because it defaults to a high ISO setting, which (just like film) accentuates the "grain", or more properly termed in digital photography, "noise". Set the camera for a low ISO setting and use the flash whenever you see the "red hand" symbol on the screen.
Apr 22, 2009 | Fuji FinePix S1000FD Digital Camera
Pictures are pink
It is problem of bad CCD Imager in DSC-T1 and that part would be replaced for correct live view to take picture.
Sony would repair DSC-T1 in bad CCD Imager problem for Free of Cost.
Please click Sony CCD Imager Support for details.
If you are in different country, let me know to guide you.
Jan 13, 2009 | Sony Cybershot DSC-T200 Digital Camera
Very poor quality pictures; grainy.
This is easily fixed - go into MENU and you will find a picture quality Q. This is designed to go from FINE - Medium - POOR in order to enable you to take more photos on you cameras memory. Install at least a 1gb memory stick into your camera and then choose HIGHEST QUALITY you will now be able to get plenty a photos at the highest quality possible gor the camera with an 8.2 megapixal those photos should be really nice. Have Fun Lancer721
Dec 07, 2008 | Fuji Finepix J50 Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Color Quality PINK
no its not the flash, it is the CCD. The replacement of the CCD will solve the problem.
Oct 28, 2006 | Canon PowerShot A70 Digital Camera
Cameras Logo
272 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
