Question about Polaroid DRM-2001G DVD Recorder/HDD Recorder
Power off, then will not come back on for several hours.
Unit will not power back up immediately after turning off. Needs several hours. Tried unplugging, no help. Unit fan will come on, no power light, no video or front display. Possible transformer? I had to change the cooling fan already, $7 at radio shack.
  • Kathleen Hunt Jan 02, 2008
    I have a similar problem, but not even the fan will come on. I simply cannot power on the unit. Please help!
Has anyone been able to locate schematics for the power supply in this thing? The undersized power supply seems to the main point of failure. Otherwise, I have been pleased with the unit. Mine was sent back to Polaroid for RMA back in February 2008. I don't think any warranty is in effect now.
Please let me know if any one has tried to trouble shoot the TOPOW DVD RW POWER857B power supply. Two of the chips I can not identify are the 8pin Dip 2216A & a 4in dip 7703
I have tried to locate the power supply manufacturer: Shenzhen Topow Electronics Co., Ltd. Their website is:http://www.topow.com.cn but my web browser can't handle the Chinese to English translation.
I think it is very likely that an AT or ATX power supply could be substituted if all the pinouts of the original power supply are known.
**Both times, my unit failed shortly after the fan started making noise. The problem has to be heat related.
Posted on Jul 16, 2008
  • 3 Answers
Check for any bulging capacitors specially the big green onces at location CE10 in power board. If any of the capacitor is bulging then you need to replace them. This will need some soldering skills. You can get capacitor from Ebay. I am not able to find these in RadioShack near my location.
Posted on Jun 30, 2008
Unit not turning on
I rekon ya burnt the motor out on it. Tell the old #*@%
it was like that when ya got it off him.
Nov 16, 2017 | McCulloch FH160G Pressure Washer
My T.V. Will power on for a couple seconds then immediately turn off! Please help!
Unplug the unit from the outlet for at least 1 hour and check if the symptoms persists. If yes, check if the unit can give an error code by following the steps below.
- Power on the unit and wait until the initialization takes place.
- Press the front panel "Input" and "Menu" buttons at the same time and hold it for 5 seconds, it will activate the error code mode. LED flashes a two digit error code. Example, if the error code is "22" the LED will flashes two times pause and then flashes two times and will repeat the error code for 5 times.
"12" means no error has occured.
Please let me know what will be the result to assist you further.
Regards,jimvincentvillanueva@yahoo.com
Mar 07, 2012 | Mitsubishi WS-55313 55" Rear Projection...
The unit will not come on. The buttons do not work, but all the lights are dimly on. The unit is getting power but it does nothing almost like it needs to be reset like its frozen or something. But I can...
Possibly dead batteries in the tstat. Turn power off, remove tstat , wire red yellow green together and turn unit on. This should make everything work, if it does the problem is the tstat.
Jun 29, 2017 | Maytag M6Y18F7A Air Conditioner
Garmin 1300 worked an hour before yesterday then I turned it off and it won't turn back on, I didn't do anything to it, it just sat on my desk. It's not the battery, I tried plugging it several times and...
I had this happen to me on one occasion with a nuvi 1300. Pressing the power button any number of times would not turn on the unit. Also, plugging in the car charger did not turn on the unit or charge it either.
I found that holding the power button for 10-15 seconds forced the unit to reboot, and it started just fine after that.
Since then, I've had an even more irritating issue, where holding the power button for 10-15 seconds would restart the unit, but it would freeze at the "loading maps." part. I ended up plugging the unit into my PC, which started it for purposes of data transfer. I then disconnected it from the PC and it restarted properly.
Try those out and see if you have any better luck.
Apr 09, 2010 | Garmin nuvi 1300 Car GPS Receiver
Dvd disc drive wont open
Unplug the power cord for ten min. then try again.............. John
Feb 01, 2009 | SDAT HTA6SD System
It turns on, but that is it
Won't turn on just flashes, tried a sister unit from truck and it works fine.
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Will not turn on
I've just experienced the same issue. I spoke with a Garmin tech about this and explained that I had also tried using the reset button, several different outlets, and the USB cable. The tech seemed very familiar with this issue and immediately recommended that I download the most recent software update from their website, then leave the unit unplugged for 24 - 48 hours to fully discharge the battery. He claimed that the unit was actually on, but a software glitch prevented both the reset and power buttons from functioning and also prevented anything from being displayed on the screen. He suggested that once the battery has completely drained, it will power up again when plugged into the USB port of your computer. The software update is said to help prevent the problem from recurring. I am still waiting for the battery to discharge so I have been unable to get this fix to work for myself yet.
Jan 29, 2008 | Garmin StreetPilot c530 GPS Receiver
No power
your set needs a tech due to excessive voltage the regulator got very hot causing it to damage when opperating systems a fan is needed to cool it off.goodluck.
Mar 29, 2007 | Yamaha RX-V1500 Receiver
"Protect" and "Push Power"
Doiuble check your wiresa again for no pinches or shorts, even at the back of the unit. Also try unplugging the unit for 12 to 24 hours. If that does not help, it may be the time to buy a new stereo because that means there is a fault in the output device, unless you kinow someone who can trouble shoot and repair solid state electronics.
Sep 18, 2006 | Sony LBT-XGR600 CD Shelf System
Polaroid DRM-2001G DVD Recorder/HDD Recorder Logo
297 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
