Question about Sub-Zero 690 Side by Side Refrigerator
How do you reset the fridge to remove the vacuum condensor light on our subzero 690 refrigerator
  • 4 Answers
You have to press the unit off button inside of the refrigerator and then press it again to turn the fridge back on. The light should go away after that
Posted on Jul 28, 2009
Sub zero 690 model if doors are not flushed right , my fridge door is little out think that is the reason flashing clean the condenser light comes after 12 hrs or so .The fridge is worth 10,000 so how can...
It is perfectly normal for the refr door on a side by side Subzero to stick out a little further than the freezer door. That light could mean several things. If you have vacuumed the condenser then you should call a repairman to look at it.
Oct 19, 2013 | Sub-Zero 690 Side by Side Refrigerator
I have a subzero 690...the freezer side is only cooling down to 50 degrees but refridgerator is working fine....control panel says to vacuum condensor. I vacuumed and also used compressed air. This made...
i would call a tech in for this,sub zeros are not like regular machines,the freezer and fridge have their own components,it's like two machines in one,whenever i've seen the vac condenser it's ussually a freon leak in the fridge evap coil so i would have to think you could have a freon leak in the freezer section,usually the bottom copper loop rots out,your talking about a machine that costs almost 10,000 dollars or more,if it is a leak i think you're covered for the first 12 years on the sealed system,you can do a few checks,look at the door gasket,does it have any rips or does it look damaged in any way,also i've seen the light switch stick and the lights stay on when the door is closed and heats up the freezer,open the freezer door and push the door switches in and out and see if the lights go out,but other than that i would call a tech in to repair your sub zero,i know if you do have a leak in the system it's could be close to a grand or more to repair and you need all the tools to do the repair.
Apr 02, 2011 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 vacuum condensor light flashing, clean vac. condensor, light still flash after 2 days.
I assume from your post you have vacuumed the condensor at the top of the unit? Did you do this regularly over the life of the unit? You have shut the unit off for at least 5 minutes (allowing it to reset) and then turned it back on and the vac condensor light still flashes? I had this same thing happen - unfortunately for me I have had to replace the condensor twice in the 12 years I have owned the unit. Luckily first time was covered by warrantly (parts and labor). Second time was in the 11th year and the parts were covered, and the labor was covered 50% after I complained......It ended up being a leak in the sealed system (condensor). If it keeps happening you may want to call for service - could be that it just needs freon, but it could be the condensor)
Sep 08, 2010 | Sub-Zero 690 Side by Side Refrigerator
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
My vaccume condensor light is flashing and my refrigerator is 55 degrees. I vaccumed the coils on the side of the fan What could be the problem ?
You may need to unplug the fridge for a few hours and let it reset itself. Also make sure coils are clean and there is plenty of air flow to the condensor..
Jul 09, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690
Call the factory at 800-222-7820.They will give you a list of the authorized servicers in your area. It sounds like the evaporator and the parts will be covered by the year 6 through 12 parts only warranty. If you are in Westchester County $625 sounds right. The vacuum condensor flashes when the compressor has too long of a run time and will reaapear a day or so after it has been reset. I assume the tech made sure the condensor fan was running and the condensr is actually clean.
Nov 30, 2008 | Sub-Zero 690 Side by Side Refrigerator
690 SubZero Side-by-Side Fridge
You need to reset the controller open the door and press and hold the "Bell" looking symbol for 15secs then release it should go away let me know if that worked
Jan 26, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
483 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
