Question about Sylvania LC420SS8 LCD TV
My TV is a Syl. LC320SLX not the LC420SS8. Thank You. I have a tilt wall mount but evidently no tapped holes on back of TV. Help!.
Here is a step by step guide with pictures to mounting your flat screen tv on the wall:
http://www.wikihow.com/Mount-a-Flat-Screen-TV
Posted on Jul 13, 2009
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Dec 17, 2009 | Olevia 332V LCD TV
I have a 37
Metric M5 screws, the wall you buy will be supplying with mounting hardware.
http://www.toptvmounts.com/
http://www.mountsdirect.com/
http://www.mountsmadesimple.com/
Just Google " wall mount for xxxxx"
Nov 24, 2009 | Televison & Video
We have a LC427SSX and want to mount it on the wall
The thread size is standard, just a metric standard. To attach the Sylvania LCD427SSX to the wall mount bracket you'll need (4) metric 8mm machine screws with a 1.25mm pitch. You'll find them at your favorite neighborhood hardware store with the designation M8 1.25x40mm. (40mm long...the 30mm would be to short)
Jul 09, 2009 | Sylvania LC420SS8 LCD TV
Having trouble mounting a LC420SS8 VESA mount
There are 6 mounting screws located on the back panel that can be used as mounts points if you wish to construct a DIY mount (or if you don't want to purchase the official mounting bracket). See the manual for their exact locations.
I used 2 of these screws (the top two) to anchor a twisted steel cable that I designed to work in the same manner as a picture frame cable mount. I then drove a masonry nail into the brick chimney above my fireplace, and connected this steel cable to that mount point. The TV is mounted there, much like the way you would hang a painting (a very large & heavy painting). The bulk of the weight is supported by the front edge of the TV, which rests on a brick mantel that is part of my chimney. The steel cable, while strong enough to fully support the TV, only acts as a balancing wire, or to catch the TV should it topple forward off of the mantel.
Be sure you know how to work with steel cable and have a strong anchor point if you try to use this method. DO NOT USE THIS METHOD FOR DRYWALL ONLY APPLICATIONS. USE FOR EITHER WOOD STUDS or MASONRY APPLICATIONS ONLY.
Apr 05, 2009 | Sylvania LC420SS8 LCD TV
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Feb 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
Sylvania lc420ss8 lcd turned off wont turn back on
Simply unplug the set, let it sit for a minute or so, then plug it back in and turn it on. I had a similar problem with the same TV and it is working fine now.
Jan 01, 2009 | Sylvania LC420SS8 LCD TV
Wall mount Akai LCT 3285TA flat panel TV
You have to get correct wall mount for this model tv.
Sep 28, 2008 | Akai LCT3285TA 32 in. LCD Television
Hannspree Television/Wall Bracket
If there are six threaded holes in the rear of your TV and the bracket supplied has only four holes I would bet that the weight requires a heavier bracket.
Apr 03, 2017 | Hannspree Televison & Video
Attaching to wall mount
The 4 screws that are commnly used are short because they are ususally wide in diameter. Besides if they are too long then they might damage the boards on the TV.
Apr 13, 2007 | Akai LCT2716 27 in. LCD Television
Sylvania LC420SS8 LCD TV Logo
88 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
