Question about Homelite Mighty Lite Lawn Trimmer
Cant start engin/ have good spark and seems to be getting fuel , replaced all gaskets and piston ring sill wont start,
  • 1 more comment
  • joe8513c Jul 22, 2009
    I have tried everything you suggested < wont egnite fuel even though it has a good spark< increased plug gap to 035 , Has a good blue spark
    Have tried everything you suggested> Wont fire with starting fluid , There is a real good spark, Increased plug gap to .035 Turning over motor with a electric drill ,
    Will get back to you tomrrow <<
  • 767 Answers
Parhaps the timing is wrong, try to recheck the igntion timmng and valve timming too.
Hope this helps!
Posted on Aug 04, 2009
    Genius:
  • 1,341 Answers
If you have rebuilt the engine, then check if all gasket are sealed,make sure everything is tight, next thing is to check the carb and valve, if it's a small two 2 stroke as I supposed it is,check the valve and make sure fuel is coming to the carb, increasing gap distance on spark plug will not make much difference.Try to choke the carb when startiing it,this may help as it's a new engine rebuilt.I suppose you have not touched anything that is to do with timing here, if you did then recheck for correct timing.The valve intake is normally located after the carb unless it is a 4 stroke engine.Make sure oil mixture is ok if applicable and there is no deposit in the carb causing this problem.
Posted on Jul 22, 2009
  • 10,865 Answers
Hi Joe. Let me help you with this annoying problem. Let's consider the fuel first. Be sure to use "new" fuel, meaning purchased within the last month. If your fuel is old pour it out of the trimmer and get fresh, new fuel. Now lets condsider spark, you say you have good spark. Excellent. Finally lets consider air. Be sure that your air filter is clean. Now let's give it a crank or two and see if it starts. If it doesn't I would get a carbeurator cleaner, a product like seafoam which you add to the fuel at the rate of one ounce per gallon. This will clean up the inside of your carbeurator with in a couple of tanks full.. Also get a can of starter fluid. Now give the air intake a squirt of starter fluid and pull the cord. The engine should start up. You may have to give it another squirt or two of starter fluid to keep it going so it is handy to ask a friend to assist you. Hopefully,. your problem is now resolved and you are back up and running. If not, read on.
Now. You indicated that you replaced the gaskets and piston ring. If your trimmer is still not running I would take a second look at your work, and check to be sure that the piston itself is not frozen up. If it is frozen up, that is your problem and you will have to use some WD40 or engine oil and a bit of emery cloth to loosen it up again.
I just rebuilt my poulan will not start now. Getting fuel and spark I can't seem to find a head gasket So i used silicone which looked to be what was used before. New head new piston & ring new carb
if you have fuel & spark there is only one thing missing and that's compression. Probably because you have no head gasket. Try to check the compression to see if it's good.
Apr 02, 2016 | Poulan Garden
I have a 1987 ford ranger the engine turns over but it wont start
Timing could be 180 degrees out try switching plug leads on distributor i.e. 1&3 2&4
Dec 21, 2014 | 1987 Ford Ranger
Cherokee revs up wont start
Your description is too vague to give specific advise. However, if you are stating that the engine turns over when you turn the key but it wont run, then you want to check a few possibilities. Fuel, Spark, compression. Make sure the engine is getting fuel. Then check for spark at one of the plug wires. Then check cylinder compression. No fuel can be a fuel pump, plugged filter, or pump electrical connection, like pump relay or wires. Spark problem can be ignition coil, coil pack, distributor module, distributor points. Compression can be piston rings, valves, head gasket. This is not everything, but it may help you!
Jun 11, 2014 | 1990 Jeep Cherokee Limited
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced all...
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Sorry for the bad news (if I am right).
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
RM 80 1986-1987 wont start
put compression gauge in spark plug hole and if its less than 100psi then you need a new oversized piston and rings ! gaskets also !!!
Jan 25, 2014 | Suzuki Motorcycles
Car overheated now wont start
If you have had the vehicle hot then I would suspect that you will have a breached head gasket at the very least depending on how hot it was and for how long. You may have damaged other component of the engine as well. Remove the spark plugs and inspect for water on top of the pistons or rotate the engine with the spark plugs removed and watch for water purging from the cylinders. If there is water present then you need to have the head gaskets replaced and the cylinder heads checked by a reputable machine shop for cracks. Other components of the engine should also be checked for damage such as the piston rings.
Jul 10, 2013 | Ford Windstar Cars & Trucks
Wont start replaced fuel pump, injectors working, spark is good, replaced computer, getting low compression reading, turns over sometimes but wont stay running
if compression is 100 psi or under you have internal failure of the motor and is why it is acting the way it is. could be head gaskets , valves or piston rings or even a crack somewhere in the compression camber. how much compression do you have on the all?
Dec 13, 2009 | 1998 Ford Contour
MY 97 PROTEGE IS NOT STARTING
check fuel, sparks,engine pressure.
if no sparks check the crankshaft & camshaft sensor
if no fuel replace fuel pump
if no pressure remove cylinderhead you may find
cylinder gasket damage , valve bent, piston rings need to be replaced
good luck
Oct 23, 2009 | 1997 Mazda Protege
Not starting
piston rings gone on piston or a gasket blown take spark plug off and put a compression tester in the hole and check the pressure goes over 100psi if not its good bye to rings buddy
Aug 07, 2009 | Cycling
2001 ford taurus wont start
It could be bad plugs, plug wires, a bad ground will do this as well. Check to see if it has the three main things.
Spark
Air
Fuel
Anther common problem is the crank shaft speed sensor. It will cause it to not spark and not start.
Joe
May 19, 2009 | 2001 Ford Taurus
Homelite Mighty Lite Lawn Trimmer  Logo
246 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
