Question about HP LaserJet 4650 Color Printer
I tried to install my CLJ 4650 printer on my home network using a print server but the printer will not work. I used the recommended driver CLJ 4650 PCL 6. I am using windows vista home edition. Any suggestions?
    Habit-Forming:
  • 121 Answers
Get another driver and try reinstalling it again....
Posted on Jul 13, 2009
  • 1 more comment
  • Duke Bells Jul 13, 2009
I need to get a wpa passphrase how do i get 1
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have an unwireless printer (Canon mx700)-what the cheapest and easist way to make this devide wireless?
The easiest and cheapest way to make this printer to work wireless is to go get a wireless print server like the one from Linksys its model is WPS54G you just connect the printer to the print server that is configured to working wireless on your network and that's it you can now print wirelessly from any computers that you have on your network.
Apr 17, 2010 | Canon MX700 Office All-In-One InkJet...
Wireless Dell laptop can't 'find' HPDeskjet 5150 Printer
this printer is (as per HP specs) only connected via USB or Wlan Print server.
Check connection using USB cable and be sure Printer driver are correctly working.
Check on Router your Print server IP address (Lock it out of DHCP)
Put both PRT and PC on same home network (normally HOME or MSWORK)
Put Printer server IP address into your printer properties/port tab/ IP.
OR check if you see your printer server in your Windows network/home network
Jan 11, 2009 | Computers & Internet
Have print server, was working great now nothing!!
HI Irwilliams,
when you uninstall and reinstall a printer on the network you have to let windows attempt to detect it again. i would recommend opening the control panel>printers and deleting the one you want to use. then click on add a printer and allow windows to detect a printer on your network.
please tell me how this goes.
Nov 13, 2008 | Linksys Wireless-G WPS54G Print Server
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
2490MF
Check that you do not have a firewall working. Set the printer by inputting the Ip or printer name when installing, do not browse for printer.
Aug 21, 2008 | Konica Minolta magicolor 2490MF Laser...
Print server thinks printer is offline
This printer works only with selected printer and they do not work with other print sever to know the print server which they work please click on this link and then click
Hide/Show Additional Results
http://search.lexmark.com/printer/US/en/22N5000
This server will cost $149 instead you can buy wireless Lexmark printer X6570 at the same price,
Good luck..................
Jun 21, 2008 | Lexmark X5470 All-In-One InkJet Printer
Zonet ZPS1001 can't detect Konica Minolta Magicolor 2400W
Persever. Change your usb points, and at the last resort get the cord from your old printer and use this type of connection. Go slowly thorugh the disc step by step and make sure you delete any previous installations of the print file in the control panel.
Oct 28, 2007 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Photo copier
Please confirgue the print server properly. Assign a particular ip address to it if possible. Then install the photocopier driver in computer and add the network port ip eual to the ip of print server. if it does not work install the print server driver if comes with it as a printer and assign it a ip.
Jun 19, 2007 | Toshiba (GD-1010) for e-studio25S, 16S,...
HP LaserJet 4650 Color Printer Logo
130 people viewed this question
Seeker5211
Seeker5211
