Whirlpool 24 in. DU900PCD Built-in Dishwasher
Problem for Whirlpool 24 in. DU900PCD Built-in Dishwasher
Removing the filter module
By stomsic on Nov 16, 2007
A mounting bolt fell out and went into the drain where the filter module and motor are. I can see it but I cannot get to it. I am concerned the bolt will clog the drain eventually. I cannot figure out how to get the filter module/motor out so I can remove the bolt. I have removed the nozze cap, washer, lower spray arm and the top of the filture moduel but that is as far as I have been able to go. Any thoughts? I don't want to pay over a $100 for service when the dishwasher is not broken! Appreciate the help.
Steve
Same Problem
Jan 10, 2008
-   took out spray arm and got down to a rubber piece with a bolt that spins when i try to get it out
-   Guest
Solution #1
posted on Nov 27, 2007
Somewhat Helpful)
doitmyself
Rank: Guide
Rating: 79%, 15 votes
I suggest you take a look at the technician repair sheet that should be stored inside the front panel at the bottom of the door. Remove that panel under the door with screw driver. Inside, attached to the panel, you should find a troubleshooting guide and solution for technician. But it is easy to follow. Look for the section that talks about removing/replacing components in question.
Good Luck
/Dara
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool 24 in. DU900PCD
Questions and Unsolved Problems for Whirlpool 24 in. DU900PCD
Do you recommend Whirlpool 24 in. DU900PCD Built-in Dishwasher?
Answer
Answer
I have a Whirlpool "Quiet Wash" built in dishwasher, model DU900PCDQ6, that doesn't fill... (More)
Answer
I have a Whirlpool dishwasher model DU900PCD that stopped running in the middle of the wash cycle.... (More)
Answer
i have an 18 inch frigidaire dishwasher that starts making a very loud noise a few minutes into the... (More)
Answer
Dishwasher starting making a terrible noise on the rinse cycle. Sounds like something is knocking... (More)
Answer
Dishwasher runs, but no water runs through it on this Whirlpool du900pcdz4
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , OH
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
