PUT A NEW BATTRY IN AND A ALT TO AND THE BATTRY LIGHT IS ON AND IT IS DRANING THE NEW BATT. HAD THE CHECK IT THEY SAY IT IS THE VOLTAGE REG
The PT cruiser uses a field signal from the PCM to regulate the voltage. If you are not getting approximately 14 volts at the battery terminals when the engine is running, either:
Use the diagram below and check the alternator output at the point labeled "A11 6 BK/GY" If this is 14 volts and there is not 14 volts at the battery terminals, then the Fusible link is bad. If there is no voltage or way less than 15 volts at the alternator, then the alternator or the PCM field signal is bad. Ensure the connector from the PCM is connected properly.
GET 35 GIFT CARD FOR EVERY 100 SPENT ON ONLINE SHIP TO HOME ORDERS
