Question about Water Heaters
I need a wiring diagram for a 1999 morgan spa pump with model number 0000pdntbaha. everything works except the pump. please advise
  • 123 Answers
Go to http://www.morganusa.com/spas/manuals/spaman01-99_01-00.pdf and print the manual it should have everything you need.
Thx
Posted on Aug 04, 2009
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
GeoSpring GEH50DNSRSA wire diagram
Here are all the resources that are available for GE heat pump without calling GE and hearing them tell you to call service technician:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
There is no wiring diagram for the bundles of wires coming from chip control board.
As general rule, these things are made to last 10 years, and afterwards will not function or be repairable. It's like a window air conditioner, except connected to water pipes, and connected to computer chip and multiple sensors, each susceptible to failure, and then the machine is used 24 hours a day, 365.
Designs have changed continually from 2009 to 2010 to 2012 models.
It's likely you got a nice piece of junk with depleted anode rod and failed sensors that stopped working and somebody got rid of it because it wasn't repairable.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Add a comment
Jun 02, 2013 | Reliance & 40 Gal Electric Mobile Home...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
Replacement timer motor needed
If you have Intermatic timer, then clock motors are available for most hard-wire box-type timers. Most pool and spa timer modules are available or have same/similar replacements. If you have plug-in timer, including power pack or portable outdoor timer or indoor plug-in or in-wall timer, then no clock motors are available.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
If you have Tork timer, then clock motor is available for 1100 series.
http://waterheatertimer.org/Tork-timers-and-manuals.html
If you have Paragon timer, clock motors will be hard to find
http://waterheatertimer.org/Paragon-timers-and-manuals.html
If you have other brands of timer, then clock motors are not available except Deihl, DIGI and Grasslin timer modules, but post brand and model number of timer so I can search my files.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Sep 11, 2010 | Intermatic WH40 - Water Heater Time Switch...
I need wiring diagram for Titan Tankless SCR 2 N-120 ASAP please
I would recommened an electrician, if the wire burned it normally means that the gauge you are using is to small. If you just reconnect the same wire back up you will burn it again. You can contact Niagara Industries technical department at 888-Titan-80 or you can send an email them at Titantech@engineer.com
Jun 13, 2009 | Water Heaters
REPLACING CENTRAL HEATING PROGRAMMER LS112
Yes, you are dropping 1. Is that wie=res required? or wire terminal location indentifier numbers? Follow your directions and then question them if you don't get desired results. Good luck
Jun 07, 2009 | Water Heaters
Wiring
The new thermostat (I assume you must be changing one) will have several possible scenarios. If you have two elements and thermostats you look for the diagram that says two elements working NON-SIMULTANEOUSLY. In other words the top element heats until the thermostat is satisfied and then, and only then the power is sent to the bottom thermostat. The wiring diagram will have the numbers and colors of the wires for everything in the heater except your feed wires. Those colors don't really matter much. You will have three conductors--two hot wires and (likely) a bare ground wire.
Hope this helps.
Mike
Apr 05, 2009 | Water Heaters
Needing part to fix my water heater?
Colburns Suppy they have a web site and will have that part in stock or they can order it. www.coburns.com
Feb 01, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
268 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
