Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My older Whirlpool Model LA9100XTN1 is not allowing any hot water through on fill up. It starts to for about 1 second then switches to cold only (on warm or hot cycle wash settings). Please help
  • 1 more comment
  • mphipps Jul 13, 2009
    Is it easy to replace the water valve solenoid?
    I need a little guidance on how to access the water valve solenoid that needs replacing...can you help me with that?
    Very helpful...thank you.
  • 15,935 Answers
The water valve solenoid has failed.
CLICK HERE to see/order the valve.
Thanks for using FixYa!!
Posted on Jul 13, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Jul 13, 2009
    Yes - 2 screws and a couple of hose clamps.
    You can have it done in an hour or so.
    Good Luck
    :D
  • blueextc3221
    sure let me write it up for you
  • blueextc3221
    Heres how to remove the outer shell... then the valve is at the back by the hoses (second video).
    Thanks :D
Whirlpool washer letting both cold and hot water in when I only ask for cold water...
The water valve is working. It only does as told. Faulty water temp switch or yank out the small board and clean the terminals then re insert it and see if maybe corrosion was all that it was. That is what I would try if it was mine.
Dec 22, 2016 | Whirlpool Washing Machines
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
When set on delicate cold/cold water, it starts to fill with cold but switches to hot water after a few seconds
Sounds like you've got the hoses switched, and the cold water you're feeling is just what is in the hot water lines until the lines get purged. Try filling on the hot setting and see if cold or hot comes out; my guess is you'll get cold water on the hot setting.
Nov 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer is not allowing watert to flow
first of all, you probably had the hoses reversed.  secondly, by turning off hot you may have damaged fill valve / solenoid and it now might need to be replaced.
Jul 24, 2010 | Whirlpool Washing Machines
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water intake
sounds like a problem with your selector switch , or you ve hooked up your hoses backwards(pretty common issue).new accutemp water temps will indeed turn hot water on even though yuove sselected cold/cold wash. Energy guidelines state that there is an optimimum "cold" temp and if your water is too cold it will turn on the hot water to stablize a warmer "cold".
Oct 27, 2008 | Whirlpool Washing Machines
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
WHIRLPOOL TOP LOADER OVERFILLING WATER
While it is filling up try this. Unplug the washer from the wall, if the water still runs then you need to replace the mixing valve. If the water stops then take the screws out at the base of the console and flip the controls back. Look for the clear hose that goes to the water pressure switch and make sure that it is connected. If it is connected take it off the switch and blow through it to see that it is clear of any obstructions.
If this only overfills after the first ore second wash then you may have the slow drain and the drain hose is in the downspout too tight.
Possible items needed;
#1 mixing valve
#2 pressure switch
#3 plumber
Jan 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
