Question about Hitachi 60SBX78B 60" Rear Projection Television
No recption pass channel 12
Someone gave me this set today and I can't get the channels to come in. We have cox cable, on the other set channels 1-99 was programmed. First off the connection in the back looks funny. Channel A does not have a standard coax connection , then comes the "to Converter" option or last Ant B with standard connection. This is the connection I chose ANT B. Pictures 1-12 come in and the rest like espn, CNBC etc is not comming in. I did the auto program as well. What can my problem be. Is this not a cble ready TV?
  • 1,694 Answers
In set-up, select TV / CATV, then choose CATV.......
Next step is auto-program.......should memorize 2-99....
Consult owner manual or download..........just a thought....T.
Posted on Dec 08, 2007
  • 111 Answers
Judging by the year, this set should definitely be cable ready. check the front of the tv if it has a control panel for a switch that says catv/normal or something similar, if it does not have that switch, check the settings via the remote.
the channel a connector may require an adapter depending on the type of connector. i had an old tv that required an adapter in order to plug the cable coax into it, it resembled an rca connector and is used on some older tv's in place of a screw on connector.
if all else fails, your cable company should be able to provide you with a tuner/converter for free or minimal charge.
i hope this helps,
Posted on Nov 16, 2007
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
We've had our 32" Vizio TV for about 4 months now and up until about 2 weeks ago, everything was working fine and all channels came in. Now, we only get about a quarter of the channels that we used to...
go to menu settings, find add/delete channel or programming or tuning. There should be an option that says "autoprogram" select this option and let the program run thuroughly. It will read and install all available channels. Do make sure tv is set to CATV and that it is NOT set on AIR.
Jan 27, 2010 | Televison & Video
Hi Someone gave me this old Sanyo TV Model # 31C4760, When I connect it with my cable it catches only basic (13 channels) instead of 60 channels. How should I see all the channels? What should I do?
If it is very old (with rotory/manual channel changer), you are out of luck unless you get a cable box from your cable company - this will let you set your TV on channel 3 or 4 and the cable box will find all stations for you. The cable box goes between your wall cable and your TV.
It your TV has an electronic tuner with a remote, try going into the setup menu and select signal source as CATV instead of antenna.
Please rate me.
Nov 20, 2009 | Televison & Video
Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
May 08, 2009 | Televison & Video
Ittermittent digital audio drop out on some channels
Did the issue ever get resolved. I have similar issues with a connection to Cox Cable HDTV and Onkyo TX-DX989. All sources (DVD Player) sound fine and not issues except channels 706 and 710 on Cox Digital receiver. I had Cox replace the HDTV receiver and the same issue occurs. I've tried optical audio and also the COAX audio ports with the same issue. The workaround I have found is to set the audio to "Other" on the Cox box, but the volume then has to be turned up quite a bit.
Jan 16, 2009 | Onkyo TX-DS989 Receiver
Channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Apr 17, 2008 | RCA F27442 27" TV
I Am Having Trouble Tuning My Channels On My VCR.
Hey is the VCR set for cable? even if it's not a local channel
could try to come in. turn the blue screen off on the VCR that
might solve your problem. If the channel is weak the blue screen will come on and block it. you can turn it off by going into
your VCR settings. Also If the cable is weak a splitter will
cause this you might have to hook the cable up directly to the
VCR to record it and watch it through the VCR. that's was may
problem once.
also you can tune channel 12 to your VCR manually if it is too
weak because of a nearby local channel it won't tune in automatically.
Nov 12, 2007 | Sanyo VWM-800 VHS VCR
Sound loss
There is a software issue with the cox cable box. You television will only react to the input it receives from the box. Get cox to replace the box and not to tell you it is a problem with the television. Scrivitron
Jun 20, 2007 | Toshiba 35AF44 35" Rear Projection...
Messed up channels.
have the cable company check your cable.thier signals are not comming into your house properly it is weak.good luck.
May 18, 2007 | RCA F19207BC TV
Televison & Video Logo
101 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
