Re: My iphone4 won't turn wifi or blue tooth on. What can...
Hold the power button and middle home button for 20 seconds until the apple appears. if this does not fix it then it is software related and can not be fixed.
Maybe i don't get it, but you can simply turn off bluetooth on your iphone to cancel all bluetooth connections immediately. Re-Enable bluetooth to re-engage your connections.
If you wan't your iPhone to "forget" a paired bluetooth device just go into the bluetooth settings and tap on the little info badge for the device you want to remove. From there you can delete this pairing.
it may be a faulty radio connection. Wires may be crossed where disabling the power to 1 affects to other. will need phone replaced. Make sure to mention blue tooth malfunction otherwise you'll have to pay for it.
Hi Try hard resetting.This restores factory settings on your phone.Be warned though,it will also erase all user data like video images and songs etc. Here's a video tutorial on how to go about it.
If your blue tooth is Usb type try to remove and replug it again,then you will observed that there is a blue tooth icon appear to the lower right corner of your computer, it means your connected or check it out to MY computer,look for the blue tooth icon. Right click the icon then choose what connection you want.
turn on your blue tooth by clicking the bluthooth sign on the bottom right of your device. and check both the options that appear then( turn on blue tooth and make my device discoverable to all) then your blue tooth is on. ok then press and hold the menus on the file u want to send. when u do it, just beam your file. when u do it. then the device will look for all blue tooths on at that time. select the name of bluetooth u want to send the file. ur problem is solved. by a cute pakistani. love u.
Try: G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2: 1st press: On both Blue Tooth & WiFi 2nd press: Off Blue Tooth / On WiFi 3rd press: On Blue Tooth / Off WiFi 4th press: Off both Blue Tooth & WiFi
