Question about Pioneer Car Audio & Video
Pioneer DEH-P1Y won't recognise AUX input
The AUX cable is plugged in and the device turned on but the unit won't recognise it is there. When pushing the source button it only changes to tuner or cd player. The manual says you can activate the AUX by turning it on using the multi control but no option comes up to turn AUX on
  • 53 Answers
Turn unit off then push jog wheel for 3 seconds new menu comes up and you will find aux setting set to on and you be all good
Posted on Oct 10, 2009
How do I use the auxiliary input option on my Pioneer DEH-P59000IB? It has no auxiliary input to plug in a wire.
After looking up your unit's info, I found that it does indeed have an aux input, but it's on the rear of the unit. Get yourself a 3.5mm aux cable (normal aux cable), pull the unit from the dash (being careful not to disconnect any wires), plug one end into the aux jack and feed the other end thru the area where the unit sits in the dash and out one side or the other of the center area of the dash (by the footwells). Put the head unit back in place and GENTLY pull the aux cable enough to get out the last bit of slack, but not so hard that you pull it out of the back of the head unit. You can tuck the extra slack up under the console where it meets the carpet. If you wanted to get real fancy, you could drill a slot in the storage area of the console large enough for the cable to fit but small enough that the end won't slip through so you can keep it all out of sight and just plug your phone or MP3 player in and hide it in the console. Then just switch the source on the unit to aux and enjoy!
Jan 18, 2014 | Pioneer DEH-P5900IB CD Player
How do i connect an aux cord to my head unit
You can go to radio shack and grab a 3.5mm to 3.5mm cable. make sure that is male -to - male. Some decks are equipped with an AUX IN in the front and some in the back and then some have both. This wire will resemble the same input end of an earphone plug. Once you have your device plugged in then just press the SRC button on your deck till it says AUX, AUX IN, or Audio. Let me know if this helps
May 20, 2010 | Pioneer DEH-P6800MP CD Player
Aux location on head unit of pioneer deh-p7500mp
there should be two aoxzilurey wires on the back you stereo red and white! plug in your male wire to the female on the back of your stereo
Feb 23, 2010 | Pioneer DEH-P7500MP CD Player
Cant find aux conection for ipod function pioneer car stereo deh-p6800mp just need help trying to get ipod playing
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing2.gif this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio2.gif and scroll through the sources and make sure it is there.
http://www.bestbuy.com/site/olspage.jsp?skuId=7710943&st=ip+bus+aux&lp=4&type=product&cp=1&id=1138086437269
or you can order the direct ipod adapter made by pioneer, which will let you control the ipod directly from the head unit itself. whichever you prefer http://www.google.com/products/catalog?hl=en&source=hp&q=pioneer+ipod&um=1&ie=UTF-8&cid=9877805020289826524&ei=_vPKSpzyKYe4NrzrpPMH&sa=X&oi=product_catalog_result&ct=result&resnum=1#ps-sellers
Oct 06, 2009 | Pioneer DEH-P6800MP CD Player
Does a pioneer deh-p550mp have an AUX. jack on the back or a set of AUX. RCA's to connect a device?
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
4. turn on the radio and scroll through the sources and make sure it is there.
5. buy cable and headphone to rca cable
Oct 06, 2009 | Pioneer DEH-P550MP CD Player
DEH-P6800MP Pioneer AUX Input
plug it in right below the sat icon on face it is a 2.5mm plug end so in most cases you need a 2.5mm male to 3.5mm male
Jul 06, 2009 | Pioneer DEH-P6800MP CD Player
Ipod worked with my pioneer deh-p3700mp before
this works on some other pioneer head units i encountered it may work on yours.
Shut it off and hold the function button until the options appear then you can scroll through and change a bunch of settings including the aux input
Dec 31, 2008 | Pioneer DEH-P3700MP CD Player
How do I turn on the "external aux" for my pioneer DEH-p7000r
You'll need an adapter cable such as this one:
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=ip+bus&i=469PIOPRCA
The adapter cable will convert the changer port on your head unit into an AUX input with dual RCA jacks. Once connected, the head unit will detect the cable and allow it to be another source (i.e. radio, cd, aux).
To connect your iPod to the adapter cable, use any iPod cable or dock that outputs to male RCA plugs.
Apr 01, 2008 | Pioneer DEH-P7000r
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Car Audio & Video Logo
1,015 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
