Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have crafsman 48" riding mower with a 24 hp intek motor
The motor is junk bent push rod's bad starter,now maybe broken rod,s is their anything that brigg,s would do about this
  • 3 Answers
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Posted on Jul 20, 2009
  • phonepro Jul 20, 2009
    Briggs will help you up to 1 year past warranty. Especially with push rod issues.
    Sergeant:
  • 384 Answers
Brigg's would try to sell you a new motor. What did you do to the motor?
Posted on Jul 13, 2009
Engine will not turnover
Is it a Briggs or Kohler motor,and since it is a 24 hp I take it it has overhead valves.
3 thousand on the valves semms awful tight unless it has hydrolic lifters.
I always set both intake and exhaust at 5 to7 thousand. will it turn over by hand with no plugs in ?
does it lock up when using starter ? (look at starter shaft bent)
I know this sounds stupid but are both pistons moving freely or is connecting rod blown.
You could have a bent valve stem.
Sep 08, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
This 24hp 48 inch deck craftsman rider was diagnosed by repair facility and said #1 cyl had a bent valve...sounds uncommon. any input, also said was a $400ish repair job
If you are looking to spend about $400 on a repair to a B&S engine you may want to buy a whole new motor instead. I had bent valve push rods, which is very common B&S problem. The parts cost me about $30.00, and a 6 pack to my handy-dandy neighbor to do the fine adjusting. Anyhow before finding the actual problem I was googling around and I was surprised at how cheaply you can buy a new engine. Does not seem to be much of a market for rebuild/exchange on these small engines.
Apr 15, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
My 24hp Briggs and Stratton ohv engine has bent push rods on one side. The top valve can be pushed in but the bottom one will not push in. Is the valve stuck in the open position? If so how can it be...
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Apr 12, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
24 hp engine. one bent push rod, second rod missing
just found the same problem on my father in laws mower (24 hp briggs) I took the engine off of the mower, drained oil, turned on its side and removed lower case. There was the missing pushrod wraped around the camshaft gear. no clue on how in the hell it did that! It also ended up breaking the govenor (quick look) will look for more damage tomorrow.
Jun 23, 2009 | Briggs & Stratton Garden
My Biggs and stratton446777 rockers dont move as it spins over
you my have a broken rod pull spark plugs out and see if pistons are moving,if so check for bent push rods,if push rods aren't bent then you may have bad cam
Apr 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Transmission won't engage
My Craftsman 24 hp twin 42in cut motor runs ok as well as the lawn mower. However will not move forward or backwards something is not connecting.
Sep 21, 2008 | Craftsman 24 Hp 48" Deck Yard Tractor
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,918 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
