Question about Pentair Pool & Spa
PUREX TRITON MINIMAX 400 Pool Heater Control Board: PAC-FAB #MWC052096R1 Unit fails to fire. I am an electrician and I have verified the following: 24VAC IS PRESENT AT TERMINALS J4(GREEN POWER LIGHT ON) SPA/POOL SWITCHES ARE GOOD PRESSURE; HI LIMIT; T FUSE INTERLOCKS ARE ALL GOOD T PROBE THERMOCOUPLE IS GOOD EXTERNAL JUMPER SWITCH IS IN PLACE problem: THE COIL OF THE OMRON RELAY ON THE CONTROL BOARD WILL NOT ENERGIZE. IF I TEMPORARILY JUMPER THE OMRON RELAY'S POWER CONTACT THE HEATER WILL FIRE (WITH ALL SAFETY INTERLOCKS FUNCTIONING PROPERLY)- BUT OBVIOUSLY WITHOUT TEMPERATURE CONTROL. ALL led's ILLUMINATE GREEN. ALL EXTERNAL CONNECTIONS TO THE BOARD SEEM TO FUNCTION PROPERLY - BUT THE RELAY WILL NOT ENERGIZE! I REPLACED THE BOARD WITH A NEW UNIT (pac-fab #MWC052096R1) BUT IT DOES THE EXACT SAME THING. WHAT AM I MISSING HERE?
  • wlm_ecu Jul 28, 2009
    PROBLEM IS SOLVED!!!
    The temperature probe was the culprit. I got great help from Brian Frickman of PENTAIR.
    The probe is easy to replace and I found one locally for around $35.
    The probe is a 10 k ohm rated unit. Mine was internally grounded.
  • Anonymous Mar 26, 2014
    I have correct power to my control center, pumps work when I jumper them. Have tested resistance on all visible fuses, they seem to check out fine. I have no illumination of the key pad and so no pumps, no heat, etc.
DId yo find the problem? My heater is doing the same thing.
Posted on Jul 28, 2009
  • tward6676 Jul 28, 2009
    I replaced the board as well, but does still has the same problem. Please let me know if you were able to figure out wat was wrong.
Purex triton minimax plus 400
You can call Pentair or go to their website: www.pentairpool.com
Then click on the "Find a Pentair Dealer Near You"
I saw about a dozen or so heater service centers in the Dallas area.
Oct 30, 2013 | Pool & Spa
Triton Purex minimax 400
dan i belive you have a faulty thermastat switch
Apr 01, 2012 | Pentair MiniMax CH Natural Gas Pool...
Purex Triton MiniMax Plus 400 power light is not turning on nor is unit. Checked for power going to unit and no fuses appear to be blown. Thoughts on what might be the issue? Thanks, Dan
if you have incoming power, you may have a bad transformer. those systems run on 24-28v. you can check from yellow wire to yellow wire coming off the transformer to see if you have anything coming out. must check wires coming out of the transformer to each other, it won't register if you check each one individually to ground. hope this helps...
Aug 11, 2011 | Pentair Minimax NT Heater
Flame blow back in an outdoor propane fired unit causing thermal fuse to open. fails Intermittantly How to fix?? suggestions please
Add a high wind stack to ensure positive vent pressure. It is a seperate option available from whomever in your area carries Purex heater parts.
Oct 20, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Triton minimax 400 pool heater won't ignite
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
Jun 27, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Have a Triton Millivolt pool heater pilot is lit and nothing!!
Low out put voltage from the pilot generator and/or an open circuit in the control circuit...the most common is a bad pressure switch (dirty filters can hamper pressure switch operation).
Jun 08, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Pool & Spa Logo
2,009 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
