Rank: Guru
Rating: 88%, 235 votes
your dish network remote does not have codes for an olevia tv, the best you can do is use the powerscan mode. here are the steps.
1)Turn ON the electronic device you want to program the remote to control.
2)Press the Mode button on the remote until the appropriate mode light is flashing.
3)Press the Address button. The mode light will start flashing slowly.
4)Press the Power button. The mode light will stop flashing and stay lit.
5)Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6)When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7)Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8)Turn the device back ON by pressing the Power button.
9)Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10)If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11)If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12)The mode light will flash rapidly when the scan has returned to the
starting point and all codes have been tested for that mode. The remote
control may not control some device models.
current settings:
1)Press the Mode button on the remote until the appropriate mode light is flashing.
2)Rapidly press the Address button twice.
For the SAT mode, the mode light will flash the number of time that matches the receiver address.
3)For the TV, VCR, and AUX modes, the mode light will flash the
number of times to indicate each digit of the current code. There will
be a pause between the flash sequences for the digits. A quick flash
indicates zero.
4)Write all of the codes you programmed on to the sticker that came
with your satellite receiver and apply the sticker to the inside of the
remote battery cover.
hope this helps,
trin
Comments:
Nov 19, 2007
- since the original suggestion didn't solve your problem, all i can suggest is to get a different remote or a different tv. craigslist usually will have people in your area unloading tv's in good condition for a reasonable price. if the code search function did not work, then your tv is unsupported with that remote.
