SOURCE: Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
SOURCE: We have a Sharp AR-335 and it is giving an error
Hello sir; There is the way to reset;
1, press "program", "interupt", "clear", "interupt'.
2, enter 14 press print.
3,turn power off and back on again.
