Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Mr. C CG13 coffee maker. Switch is on and green light lit. Hot plate does not get hot and no brewing.
    Problem Solver:
  • 14 Answers
17 bucks. this happens to all these. throw it away and get a new one at walmart for 17 bucks. that's what I did.
Posted on Aug 25, 2009
  • apvangun Aug 28, 2010
    That may be the correct answer on Replaceya.com. Not very helpfull in this case.
Does not brew coffee and hot plate is cold
There is an overheating safety fusible link under the hot plate. It is probably burnt open.
murf427
Aug 01, 2012 | Krups Caffe Bistro 867 Espresso & Coffee...
Coffee will not brew, all lights are on, everything is in the right place, filled, plugged in, etc. What could be wrong?
Is the coffee urn heating plate getting hot? If it is then I would focus on the actual heating element, I think that is your problem and one that is not easily serviceable.
Feb 02, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
The unit brews coffee OK. About 2-3 times per hour, the brewing element turns on and bubbles for a few minutes. This annoys me. Will it shorten the life of the coffee maker? It has done this since it was...
Hi. The pot is turning itself on because the thermostat is telling it to do so, because the coffee in the pot is getting cold. You might try feeling the surface under the pot is sitting on to see if it is hot. if it is not hot the keepwarm element is not working, if so get rid of it and but a heavy duty coffee maker ( Bunn ) It does not pay to repair them because the fright to and fro, plus the cost of the repair. Probably made in China. Good luck. bobbyone
Aug 13, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Nov 21, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Coffee Maker Not Working
hi i hope i can help you? may i please ask does the water heat? if not if you have a multimeter open it up and check the hot plate. and the connections even if the light is on there the other side of the switch. you can get these meters from maplin electronics for about £8 £9 very cheap but will last for many years.
May 05, 2009 | Coffee Makers & Espresso Machines
Bunn UPR warmer too hot
Try connecting two elements in series. See if this keeps it hot enough. (One switch controlling both burners.) See if another brand of burner will fit in the hole. Check to see if the wattage is lower.
Feb 06, 2008 | APW Wyott Mr. Frank Hot Dog Broiler & Bun...
Mr coffee model isx43 12 cup
Turn the :Warming Temp." dial to the right, this is the hottest the heating plate will get and should resolve your problem. THedial is locatedjust under the clock.
Feb 02, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Warmer stopped working
the coffee maker brews but the pot warming plate isn't hot
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee won't brew
It is probily the thermal switch between hot wire and element. Check to see if you are getting power through this switch.
Sep 17, 2007 | Mr. Coffee TFTX85 Coffee Maker
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
463 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
