Try this site for a service manual
Service manuals electronic components datasheets and equipment schematics...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
SOURCE: SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
SOURCE: a new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
SOURCE: U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
SOURCE: how to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
