Question about GE Spectra JBP78 Electric Kitchen Range
The bottom heating element in the oven has stopped working
The oven is 4 yrs old. The broiler heating element and range burners still work. how easily is this to replace?
  • 54 Answers
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Posted on Jul 14, 2009
My Crosley oven has a new element and timer and still will not heat up
It sounds like you need to replace the burner receptacle, in either the broiler or the bottom oven burner( heating element) or both. When it exploded it burned the contacts in the heating element.
Apr 11, 2014 | Ovens
Tip
I'm wondering if my Jenn-Air Model JER8885QCS needs a new probe or not. It's a...
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but can be found with the technical documentation that comes with your range. Most manufacturers place a tech sheet somewhere along the back of the range, or inside the console for qualified technicians to use as a troubleshooting aid. Refer to this if an “F” code is displayed on your operator console. The probe may also exhibit other symptoms without generating an error code. You could have undesired heating results (too hot or too cold), or slow preheat times.
The location of the oven probe can vary on different models as well. It will be mounted on the back or side of the oven wall (usually in the upper right or upper left corner). If you suspect you have a bad oven probe, a resistance check can be performed to determine if the probe is good. To accomplish this, unplug the range and remove the back panel. There are still dangerous voltages present even when the oven is not on. There will be two heat insulated wires coming from the oven probe behind the oven. Disconnect the wires and perform a resistance reading across both wires at room temperature. If the probe is good, it should read around 1100-1200 ohms*. If the reading is too low (shorted) or too high (open), replace it. However, I would take a good look at the interconnecting wiring FIRST. If you have a connector plug on the oven probe, often the plug pins will oxidize and not make good contact. This gives false readings and can lead to erroneous error codes. Some manufacturers recommend cutting the connector plug off completely and hardwiring the leads together by using heat resistant ceramic wire lugs. This provides a more permanent and reliable connection. The lugs can be purchased at most hardware stores. A new oven probe roughly costs about $35 - $45 and can be found on line at several appliance parts websites. Higher end model prices may be more.
To replace the oven probe, simply remove the mounting screw from inside the oven cavity, disconnect the wires and pull the probe out. Insert the new probe by feeding the wires through the opening in the back of the oven first and out the back through the insulation (a long screwdriver can assist you in making a visible hole through the heat insulation to feed the wires easier). Once you have the wires through the back of the oven, reinsert the mounting screw and connect the wires leads together. Reinstall back panel.
*NOTE: Keep in mind resistance readings will be higher if the probe is hot. Make sure you check the temperature at room temperature.
I hope this information is helpful..
on Mar 31, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool electric range oven broiler not working
Hello. This is a common failure for this range. Replace part number
9762215, price varies but about $100 average.
Apr 07, 2014 | Kitchen Ranges
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Oct 03, 2009 | Amana AGDS902 Gas Kitchen Range
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
The heating element on the bottom of the oven does not work.
lots of those old elements are still out there...some come out with simple pull...or two screws holding the wires!.. take to appliance store (sometimes even lowes!)
Mar 15, 2009 | Kitchen Ranges
Oven, broiler don't work
The main control board is what you need to replace here.Please Rate This !
Jul 06, 2008 | Kenmore Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
706 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
