LOST MANUAL. I HAVE A ONE YEAR OLD DUCTLESS COMFORT AIRE CONDITIONER. MODEL NUMBER B-DMC24DB-1. UNIT FLASHES WHEN TURNED ON BUT QUICKLY TURNS ITSELF OFF. THIS HAPPENS MANUALLY AND WHEN USING THE REMOTE
  • 3,230 Answers
Download your manual from the below link -
http://www.appliancefactoryparts.com/airconditioners/comfort-aire/comfort-aire-manuals.html
Just serch for the model number.
Good Luck!!
Thanks
Posted on Jul 13, 2009
The error code E1 is lit on the front panel of room air conditioner. The instuction book is lost and I can't locate the model number. It says energy star and comfort touch and come with an remote...
E1 is refering to the air filter. If turning the unit off and unplugging doesn't reset it then you probably have a PC board or sensor failure. None of these units can actually detect a dirty air filter. All it does is set a timer that turns the E1 on after what the manufacture determines is average.
Hope that helps.........
Jul 28, 2008 | Sharp Heating & Cooling
My Maytag model number MEY18F7E will turn on for about 10 seconds then quit and trip the breaker. It just started doing this about a week ago. Has been working fine since I purchased the home several years...
Sounds like you have a bad compressor, something is either shorted out, or drawing too much power causing your breaker to trip.
Is this a window unit, or a ductless unit?
Aug 23, 2013 | Maytag Heating & Cooling
I have a ductless window LG airconditioner that keeps show P2; I have lost the owners manual so I can't remember what this means.
P2 indicates a circuit protection shut down. Turn the Unit Off & Unplug it for 15 minutes. Then plug the unit back in, and turn it ON. During that time out, the electronics should have reset and the unit will go back to your original settings. If this continues to happen contact LG Customer Support 1 (800) 243-0000.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Heating & Cooling
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Jun 13, 2007 | LG LS240CE Split System Air Conditioner
R22 LOST (SOMEONE STOLE PIPE),
be careful but dose in gas slowly until the frost line reaches the end of the evaporator
Mar 21, 2007 | GE Quiet-Aire Ductless Mini Split System...
Heating & Cooling Logo
172 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
