Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Where is lamp located so i can change it?
I'm gonnas change the lamp but where is it located?
  • Mitsubishi Master
  • 8,617 Answers
Just remove the lower front panel by pulling it straight off and you will notice the lamp compartment on the left front behind that panel.
Posted on Jul 13, 2009
Have a 01 ford focus with 2.0 dohc se got from father when got hazard lights worked and all four signals now no signal lights or dome light or hazards where is the signal relay located at in the fuze...
remember that any lighting upgrades on Ford that are manufactured before September 2007, such as LED bulbs will require changing out the flasher. For 2 terminal flashers your looking for a part number EL 12 because it operates on Electro Magnet function vs the Bi Metal Resistance function. so it will perform the ultra light load of LED,s and will also perform mixed load function ( LED's and Incandescent lamps on the same circuit )
Happy Tuning...
May 07, 2014 | Cars & Trucks
Cant get the front panel off
Just gonna have to put some muscle into it to release the tabs. Just be a little careful, you wont hurt it.
Nov 28, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I am trying to find out the fuse for dash lights on 98 pontiac montana where is it under the hood and what it looks like big one or small
sounds like your problem is gonna be more aimed at what gm calls a lamp control module im not sure bout the exact mounting location on the montana but i would assume it is directly behind the radio in the dash, could also be the head light switch and/or dimmer switch.
Jul 30, 2010 | Pontiac Montana SV6 Cars & Trucks
Need tips and location of oil filter and drain plug.
well the drain plug is ALWAYS gonna be on the bottom of the oil pan bolted to the bottom of the engine, the filter is either gonna be on the oil pump near the oil pan or it will be screwed into the side of the engine block, either way you should be able to see it just from a quick look from underneath the car.
Feb 25, 2010 | Saturn L300 Cars & Trucks
How do I remove the cover on a 2002 325i BMW tail light wiring? thanks
Do you need to change a bulb or are you changing to custom lamps. If it is bulb replacement open trunk/boot (depending where you live ) the access for the tail lamps is at the rear corners of the trunk, If you are changing lamp lenses or assembly remove the screws( same location ) at lamp corners
Jul 09, 2009 | 2001 BMW 325
How to change the lamp in a sony wedge tv
if you look at the back bottom side of the tv you will see 2 big plastic screws that you can unscrew with your hand, then pull the bottom from part of tv with just a little preassure will come off, then you gonna see the box where the lamp's at, just unscrew the two screws and pull out the lamp, it is very simple, it does not take too long to do this.
good luck
Nov 13, 2008 | Sony KDF-42WE655 Television
Dash lights
The dash is lit by one or more bulbs located on the edge of that clear plastic. You may be able to get to the lamp holder by reaching up behind the dash. If not there, then the dash will need to come off.
Jul 03, 2008 | 2000 Toyota Camry
Sony VLP-SC50 lamp shuts down and temp/fan light blinks
that means the fan is broken... say to call sony customer support. Probably gonna charge you an arm and a leg to fix it so im gonna try to nstall a new fam myself
Feb 03, 2008 | Sony VPL SC50 Multimedia Projector
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
