Question about Garmin 010-00358-00 GPS Receiver
Garmin Nuvi 770, Unit powers on, touch screen works, then it won't, then it does, then it wont, then...you get the idea.
  • 10,865 Answers
There is a reset button under the frame around the screen. Carefully pry the frame up, there is a fingernail slot at one point. Once up, push the reset button and you may be back in business. If reset does not do it, you will have to go to garmin.com and speak with a tech from the service center on how to proceed.
Posted on Jul 13, 2009
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
My garmin nuvi 750 screen lights up, but no information comes up
Try resetting it to original by powering up while touching and holding right corner of screen, choose "yes" when it asks "Do you want to erase all user data?"
Restart
Apr 22, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
My garmin 255w nuvi keep turning off and wont turn on
It is a good idea to perform a hard reset on your Garmin Nuvi after updating the software.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 650 Touch Screen trouble...
Yes, this is a common problem with a new style screen being used by SHARP. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Dec 07, 2009 | Garmin GPS
Our Garmin Nuvi was working until we stopped the car.
I've had this happen on three successive Nuvi 760's which I sent back, the serial numbers all suggested that they came from the same production batch..
Eventually I got a Nuvi 770 which has been fine. I understand that it's not a problem with the basic design as the 770 is really just a 760 with more memory, but it's probably a fault with a batch of components used during a production run.
This is not a DIY repair; contact Garmin even if your unit is out of warranty as they might offer a goodwill repair for free or at reduced cost.
Jul 03, 2009 | Garmin Nuvi 760 Car GPS Receiver
I have a Garmin Nuvi 770 that won't "speak" when navigating
Frequently (about 20% of the time) when I have my Nuvi 770 plugged in, in the car and I turn it on, it gets stuck at the start up screen where it says, “Loading maps” I wait several minutes and it never completes. Then I turn it off and turn it back on and it comes right up, but with no voice. When I go to Tools > Setup > Language it shows no language and I cannot select one. I have to plug my Nuvi 770 into the computer, run web updater, it detects that I already have the software loaded and I select the option to download it again. When it has completed, I unplug the Nuvi and then go to Tools > Setup > Language and select American English.
Mar 22, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Garmani nuvi 780 freezes on "updating bluetooth firmware 0%" when turned on
Worked for me but not sure why, I had the same problem of freezing when updating Bluetooth firmware on a Nuvi 770. I chose to reset all user data (press lower tight hand of touch screen while powering on) and next reboot it updated firmware sucesfully. No idea why this worked.
Feb 20, 2009 | Garmin nuvi 780 GPS
Garmin 750 - 90 days old
Had the same problem-try this- leave your nuvi off for about 4 hours. Push the power button to the right(lock position) and then to the left (power on position) and let go. I suspect temperature (getting overheated is the problem. This worked for me.
Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin 010-00358-00 GPS Receiver Logo
456 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
