Windows vista home edition on acer aspire 5515 will not boot after installing a mouse previous to the last power off
  • 674 Answers
Try to repair it, or restor system
Posted on Jul 13, 2009
Why is my laptop backspacing/deleting content and webpages?
Change Your Keyboard.... The Backspace key is damaged... It is sure that your problem will be solved.
Jul 10, 2014 | Acer Aspire Computers & Internet
I cannot start up my acer aspire 584g32bn
Safe Mode and System Restore can fix startup issues in an Acer Aspire One, but if the computer won't even load the boot screen, the problem could be related to the basic input/output system (BIOS).
The Acer Aspire One 110 and 150 are two models that can have BIOS-related problems that prevent the computer from booting.
You can upgrade the BIOS through a USB flash drive to repair this issue.
If you are able boot past the startup screen, but can't sign in to Windows, you can use Windows Advanced Boot Options to bypass startup problems.
Go to the Acer website (see Below).
http://us.acer.com/ac/en/US/content/drivers
Click "Support," then select "Download" from the menu on the left.
Select "Netbook" as the product family.
Click "Aspire One" as the product line. Select "AOA110" or "AOA150" as the product model.
Click the "BIOS" tab.
Click the download button and save the file to the desktop.
Go to the desktop when the download completes.
Double-click the file to open it.
Drag-and-drop the folder to the desktop.
Double-click the folder to open its contents in Windows Explorer.
Double-click the "BIOS_Acer_3310_A_AOA110 & AOA150" folder.
Double-click the "Dos_Flash" folder.
Insert a blank USB flash drive into a USB slot.
Drag-and-drop the "3310.fd" and "Flashit.exe" files to the flash drive.
Right-click the "3310.fd" file. Click "Rename."
Change the file name to "zg5ia32.fd" and press "Enter."
Connect the AC adapter to the power jack.
Hold down "Fn" and "Esc" with one hand, then press the power button with the other.
Release the "Fn" and "Esc" keys when the power indicator light comes on.
Wait at least seven minutes for the system to fix the BIOS and repair the Acer Aspire One startup issues.
The computer will restart automatically when the process is complete.
Other Models
Turn on the computer.
Press "F8" before the Windows logo appears to access the Windows Advanced Boot Options menu.
Scroll to Last-Known Good Configuration.
Press "Enter" to load Windows.
If the OS fails to start up, hold down the power button for 10 seconds to turn off the computer.
Press the power button to turn the Acer Aspire One back on. Press "F8," then select "Safe Mode" from the options.
Log in to Safe Mode. Click "Start," "All Programs," "System Tools" and then "System Restore." Click "Next."
Select the last working restore point from the options. Click "Next."
Click "Finish" to run System Restore and recover the Acer Aspire One to a previous state.
Apr 21, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 5515 laptop is not booting and I'm unable to reinstall the OS
If that is the case, remove HDD and test. Replace if necessary.
Nov 18, 2012 | Acer Aspire 5515-5187 Notebook
Acer aspire 5515 blue screen
hi
yes it may be related to bios setting . Just enter your bios in the laptop (F2)
and for HD change the SATA to ATA or vice-versa. SAVE and retry boot.
(it can also be AHCI to ATA or ATA to AHCI.)
Aug 12, 2012 | Acer Computers & Internet
How do I get into the registery of an Acer aspire 5515 registery with Windows Vista home basic operating system to clean out Security Tool inputs?
Click on Start->Run or press the windows button and r simultaneously in key board. Type "Regedit" without double quotes. Press Enter. Take backup of registry before editing it and don't play with it if you are not confident of what you are doing. Your system may not boot if you do something wrong to registry.
May 20, 2010 | Computers & Internet
Acer Aspire 5515 stopped responding and will only boot as far as the Microsoft loading screen
Try tapping the "f8"key when booting - it should allow you to choose "safe mode".
If it starts up - scan the PC for errors (including bad sectors on HDD)
If it still does not boot - I'd try booting from the windows install disc and use the installers repair console.
If that wouldn't help - I'd get a bootable CD of Ubuntu or some other OS and try and repair the windows installation from there.
Oct 23, 2009 | HP Compaq Presario R4000 Notebook
Installed AT&T Communication Manager on ACER 5335 now it freezes
enter safe mode and uninstall the ATT software..reboot.
http://www.aa1consulting.com
Jul 26, 2009 | Microsoft Windows Vista Home Premium with...
Laptop mouse won't work.
Hi
1 > Check in the safe mode - To access the safe mode need keep tap on F8 key
> Need select the Safemode if it is the same
2> Check in the safe mode with command prompt
Type this command
%systemroot%\system32\restore\rstrui.exe,
Follow this steps for xp system restore
http://support.microsoft.com/kb/306084
Follow this steps for vista system restore
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
With Regards
anand_manj2005@hotmail.com
Apr 13, 2009 | UltraLast ULAC3660L For Acer Aspire...
Installing XP/downgrading from Vista
you can not install under windows environment if it is a down grade. i thought maybe that is how you are doing because you said when you click intall...?? you have to boot your XP home from the cd drive and there you follow the instructions on how you wanted it installed. in XP series, you only get to use the mouse when windows is almost ready for intallation. but initial setup is in DOS mode only.
Apr 07, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
