Ovens Logo
Alison Mead Posted on Sep 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
I was using the fan oven as normal when I heard a loud pop & everything stopped working - the LED display, the hob, grill & both ovens.
Jon Lamb
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Master 110 Answers
  • Posted on Nov 26, 2015
Jon Lamb
Master
Level 3:
Director Badge:
Answers
110
Questions
Helped
132016
Points
1321
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Lawrence Oravetz
Level 3:
  • Hotpoint Master 10,558 Answers
  • Posted on Sep 26, 2015
Lawrence Oravetz
Hotpoint Master
Level 3:
Answers
10558
Questions
Helped
2700152
Points
29284
Reset the circuit breaker in your power panel. That won't fix the loud pop you heard but may restore the led display until further investigating can be done. Start with the heating element. That will make that popping noise you heard.
1helpful
My Hotpoint SY36 oven has started making a clicking noise behind the control panel. The temperature light does not come on although the oven does heat up still.
If you have a problem with your hotpoint cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
What happened- i was using the stovetop and the oven and i heard a loud pop?
Good Morning Friend,
I understand you were using the stovetop and oven on your Electrolux range. You heard a loud pop, and are wondering what happened. I suggest contacting your local authorized dealer for further assistance. They have been trained on your appliance and should be able diagnose your appliance and determine what cause that loud pop.
-Best Regards-
WP
2answers
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
How to Repair
Buy Paul Beer
The main fan assisted oven on a Hotpoint BD35 double oven stopped working so I replaced the element, thinking that would be the obvious answer. Unfortunately it is still not working and I notice that the...
Is there a black pole sticking out that goes in when you close the door, my Hotpoint freestanding cooker has it on the right hand side, once this is pressed in the fan and heat starts, i had to replace it on my cooker as it went faulty and stopped things working (all I had was the main oven light on, these are usually like a little black box that are situated on the side of the oven just behind the main metal panel on the outside and will normally have 2 pull off spade connectors connected to it.
i don't have the same model as you but hopefully this mig help you.
Zanucci Electrical fault. Oven cuts out and fO8
Is the model number correct. ZBF360X.
Anyway the error code fo8 normally relates to a faulty Tangential Fan.(Cooling Fan),which can be found on teh top of the cooker behind the control panel and it is there to cool said panel.
Hope this helps.
3helpful
No heat from cooker
If the fan is working o/k, then it is probably a faulty heater element.
This is located at the rear of the oven behind a removeable cover.
Please rate my solution.
Thankyou.
3helpful
2answers
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Stove not working
a bit more info please, electric or gas, fanned or coventional.
4helpful
Oven blew a fuse
The POP sound normally indicates a short circuit fault (as opposed to overload) you need to have it looked at by a competent person.
Nov 17, 2008 • Ovens
Top Hotpoint Ovens Experts
Mike Cairns
Mike Cairns
paul fairbanks
Larry Ng
Larry Ng
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
