SOURCE: Audi a4 driver dood wont open
Enter car from left rear behind the driver and see if you can manually unlock it from the inside. Then use remote to test it.
SOURCE: 2003 cadillac cts rear driver window and door lock not working
bang on the door hard and put the window up.if there is a dead spot in the motor from lack of use,the motor will start.
SOURCE: Front driver door won't open from the inside only
The linkage is probably broken or snapped out of place from inside the door panel.
You'll feel that the handle is much easier to move than the other doors.
If you are confident and able, take the door apart removing the screws and snap pieces and look for the missing linkage. It's usually a snap piece that holds a rod in place on the back of the handle. They break all the time, or dry rot, or jarr out of place. They're easily available at your local auto parts place or even dealership for just a few bucks!
SOURCE: 2003 Nissan Murano Driver door won't lock or unlock with keyfob
The key fob is the remote. But the remote type that works like a key. The remotes that you just need to carry on you to start the car or truck. That is a Key Fob.
Thanks Jay!
