Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Frigidaire 18" dishwasher
My dishwasher is filling with water and leaking out when it is not on. it runs the cycle fine but later the water comes in and stays.
  • 25 Answers
Check the electrical water inlet valve for sand or unwanted partical on the valve. If the valve can not be open and clean, change the valve.
Posted on Nov 16, 2007
Dishwasher not draining
It has a drain line that goes to a fitting on the garbage disposal or the sink drain if no disposal. It is held on with a hose clamp and can clog easily
Apr 06, 2014 | Frigidaire 18" Built-In Dishwasher
Runs through all cycles water doesnt fill properly
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Feb 22, 2011 | Frigidaire Professional Series 24 in....
No water is getting to the dishwasher
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 10, 2011 | Frigidaire 18 in. FDR252RB Built-in...
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Fridgidaire FDB1250REC dishwasher comes on, fills some water in bottom then cycle stops but can hear motor turning on and off, water will drain when I try to start cycle again.
This seems to be the "anti flood" device at the base of the washer is triggered due to water at the base of the washer. This safety device consists of a polystireene float and a micro switch that detects water leaks/spills and automatically puts the washer in pump out mode. You need to find the leak (hose or clamp)dry the base and rectifythe leak it before the washer works.
Mar 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher is not cleaning dishes.
you need to check to see what the temps of you water going into the unit is. it needs to be atleast 120 degrees. if not your unit may be waiting to heat the water, until it does then it wont go into the next cycle. it could be the heat cycle is not working so that would cause the unit to not advance.
let the unit run thru the place you think its stopping, but not more then 2 hours. if its not advancing then you might have a bad heating element.
Jan 06, 2009 | Frigidaire 18 in. FDR252RB Built-in...
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
My dishwasher shuts itself off
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
Aug 03, 2007 | Frigidaire 18 in. FDR252RB Built-in...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
97 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
