Question about HP Office Equipment & Supplies
My HP 7410 will not print in color. Black
My HP Office Jet 7410 will not print in color. I can print black and a color copy if fine, it just won't print color.
My hp printer officejet7410 made a wierd noise and now the only color that anything prints is in reds and pinks.
Posted on Sep 02, 2009
How do i remove the print head from hp office jet 4620
remove all the inks and look for a release lever might be grey in color or black lift the lever and remove/lift the print head assembly from printer... your inks sit directly on top of the print head assembly
May 03, 2014 | HP Officejet 4620 e-All-in-One Printer,...
HP Office jet printer slow
I think it's that black cartridge!
The problem you've described is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
Assuming the cartridges are original HP (not re-manufactured or refilled) you can check the warranty status by CLICKING HERE
Let me know how you make out.
Ben
May 03, 2012 | HP OfficeJet 7410 All-In-One InkJet...
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even when the document is black and white (using up the color ink) 2) It prints much more slowly than it did...
go into your driver and change your color preferences to black and white. that way when you want to print color you actually have to tell it to do so. which will save your color ink, and will print much faster. full color printing of a black and white document uses all ink colors except black to make what is called process black.
Dec 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Office Jet 7410 printer copies, fax are black
If you make a copy and it is black, either the ccd (reader is bad or the lamp is out) either is the end. Take it back to staples if you can.
Make sure you unplug it for about 1 hour and plug back in and try a copy.
Apr 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
Color Copies
Please scan it in and then change the color using any editing software
Feb 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Can this machine COPY from the Black Cartridge only.
Click Start - All programs - HP - HP Director/Solution center.
In HP Director/Solution center. Click Settings - print settings - printer settings . Click on the Colors tab. Enable the option Print in grayscale and Black print cartridge only.
This is the only way to print with single black cartridge.
Thanks
Dec 21, 2007 | HP OfficeJet 7410 All-In-One InkJet...
314 people viewed this question
Seeker5211
Seeker5211
