Question about Aprilaire 600 Humidifier
Aprilaire evaporator screen produces a white runoff to the sump pump which clogs causing it to jam. are there uncoded evaporators?
  • 86 Answers
Replace the AA#35 water panel annually also try poring a touch of bleach where the pump is the pads have the coating to keep them from rusting you miht be able to find a generic paper model if you look at your local department store
Posted on Jul 26, 2009
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
On my Aprilaire 560 humidifier it says to replace water panel evaporator annually. Are there any documented instructions on how to do this?
Dear Reader,
If you visit aprilaire.com, you can go to the "OWNER'S CENTER" tab at the top of the page. With the cursor on "OWNER'S CENTER", more options will appear. Click on the "OWNER'S MANUALS" option. Scroll down to the bottom of the page and you'll get to a list of our older model humidifiers. Click on the first link which includes your model 560. By clicking on this link, you will be able to download the owners manual for your 560. On page 16 of this manual will be the step by step instructions explaining how to perform the water panel change.
If you have any further questions regarding this or any of our products, please feel free to contact our customer service department 800-334-6011 at your earliest convenience.
Kind regards,
Zach Handyside
Customer Service Specialist
Research Products Corporation
www.aprilaire.com
Nov 16, 2010 | Aprilaire 600 Humidifier
Humidifier causing sump pump to cycle repetativley
I'm assuming this unit has a reservoir installed in the heat duct and has a rotating pad in a wire cage -- is this correct?
If so, it sounds as if the float valve in the humidifier reservoir is out of adjustment or the valve is leaking, The reservoir is overfilling and running into the sump.
There is an adjustment on the float, if lowering the float does not solve the problem, the valve is leaking -- it'll probably need replacing.
May 05, 2009 | Aprilaire 700 Humidifier
Orifice clogs to Aprilaire 600
http://www.aprilaire.com/themes/aa/en/manuals/600a.pdf look at page thirteen in this manual there is allready a inline filter on the unit. hope this helps
Jan 06, 2009 | Aprilaire 600 Humidifier
Routing waterline to pad
1/4" flexible copper pipe. Tap into your cold water line using the included saddle valve (pierces the pipe), attach the 1/4" flexible copper pipe to the saddle valve on the cold water pipe and the solenoid valve on humidifier unit using the included compression fittings. Tada!
Dec 10, 2008 | Aprilaire 550 Humidifier
The humidifier has stopped producing mist
boogiecheck is right, the one pictured uses natural evaporation( no white dust) I just ordered one from abdistrsupport@gmail.com and mine works great. I own 3 total.
Dec 07, 2008 | Venta - Airwasher LW44 Humidifier
Aprilaire 600 bypass water flow rate
The water is only dispensing over the evaporator pad while the furnace is in the heating mode. When the furnace finishes cycling the humidifier will also stop.
Mar 04, 2008 | Aprilaire 600 Humidifier
Produces a ton of white dust... Why???
Your V5100N ultrasonic humidifier generates a fine mist by vibrating the water at an exremely high speed. The water doesn't actually evaporate until after the water mist is in the air. As the tiny water droplets evaporate in the air, the calcium and other minerals settle on your floors and furniture.
Humidifiers that evaporate the water in a filter wick, or with heat, do not generate dust because the water evaporates inside the unit and the calcium is trapped inside.
You can avoid the dust problem with your humidifier by using distilled water. Distilled water is available in most stores that sell bottled water in gallons...but be sure to choose "distilled" water, not "purified" water. Try the distilled water in your steam iron also...if you have one. It will last longer.
Feb 29, 2008 | Vicks V5100N Humidifier
No water to my Aprilair model 550.
Some sump pump have a safty switch that will not let the hum. come on if the tank is full of water, I,m not sure if this is the type that you have but make sure that the pump is pumping water. Also your humidistat have an internal switch that it should be set to bypass not to power Note: some humidifier have their own power supply the 550 dose not
Jan 26, 2008 | Aprilaire 550 Humidifier
Aprilaire 600 Humidifier Logo
167 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
1STHVACMAN
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
