Question about Huffy Alpine 24 Youth All-Terrain Bicycle
I have an older Huffy, with grip shifters. The shifter (left hand) is almost impossible to shift the chain from the small sprocket to the middle or largest sprocket. The deraileur seams to be moving freely when moving it manually. I have installed and lubricated a new cable & it is impossible to turn
    President:
  • 1,126 Answers
First, try to isolate the trouble like you have... obviously the derailieur is moviong freely. Next, I would disconnect the shifter cable from the derailieur (make sure to mark previous position of cable) Next, shift the left hand grip to see if the grip moves freely, you've already replaced the cable, soooooo, disassemble the grip and grease or replace the grip shift unit...hope this helps
Posted on Jul 13, 2009
Repair manual shoprider sovereign
you derailleur cable sounds like it is loose. put the shifter into the lowest gear. Release the cable at the derailleur, pull it tight with your fingers then tighten up the set screw/nut to hold it in place, this should allow the shifter to complete the "throw" fully and move the chain into place on the large sprocket.
Sep 02, 2014 | Cycling
Grip shift keeps slipping shifter
there is usually a very small set screw (2-3mm Allen both) that holds the shifter in position on the handle bar. This probably needs to be tightened a little.
Apr 21, 2014 | Huffy Alpine 24 Youth All-Terrain Bicycle
Which shifter should I change while riding?
Well, the basic principle is this: If you want a big change use your left shifter and if you want a small change use the right shifter. The right shifter is more for nuances and the left one will make a big difference in your riding speed and difficulty.
Jan 17, 2013 | Cycling
I don't understand how to shift my 12-speed Adventurer bicycle and am looking for online manual or some help. The right-hand shifter has numbers 1-6, but I don't seem to know how to match it up...
It sounds like you have 2 sprockets on the Front (Crank) sprocket-
and likely 6 sprockets on the rear?
So-- when you have the chain in the smaller diameter sprocket on the front, and you have the chain on the biggest sprocket in the rear-- you have the most mechanical advantage-- and you can climb hills the best-
If you started in this gear, (sand you are pedaling on the level road) you could gradually work you way up thru those 6 sprockets-- until you are cruising-
Then -- for all practical purposes, you can shift the Front sprocket to the larger sprocket, and now you have at the fastest ratio possible. (In other words you pedal slower, for a faster rotation of the rear wheel-- make sense?)
There is no need to switch back and forth 12 times, as you go gradually faster-- (It is not like driving a big truck! :-)
Does this help?-- if not, let me know what I missed in your question?
Mack B
Jul 04, 2011 | Cycling
How is the "ten speed"
I am answering, but hoping this is not a trick question. ALL Bikes from that time period had two shifters, one the speed gears and one to represent the Hi-Low Function of the gears. In other works, when shifter one was move, it moved the chain on the front sprocket to the Low Gear ratio, Which would translate on the rear 5 piece sprocket as gears 1-5. These were change by slightly moving the second shifter, which in turn would move the chain a slight bit and onto the next sprocket in the line. You could go in any combination of gears from 5th to 1st from 1st to 6th, all by moving the correct level, which would move the appropriate chain guide and mode the chain to the correct sprocket. Let me know if that helps at all. I tried to remove the technical in order to keep it simple. I can make it harder and more technical if you would like.
If you are trying to get to a certain answer, please do not hesitate to ask any question, other than where to get parts, cause that part of Huffy's business is no more and Huffy, really isn't the same Huffy as was in 1989. No really, different organization all together, they basically sold the name and ops.
Jun 30, 2011 | Cycling
Where can I get manual for new Shimano EF-50- EZ trigger shifter???Not familiar with this shifter usage---wher is lowest gear for hills??? Which nunbers do i use for just regular bike paths??????
The manual will not help you understand shifting. Your lowest gear is (Left hand =Front gears and brakes, Right hand=rear gears and brakes). Your easiest gears are the ones closest to the frame of the bike, so, 1st gear is small sprocket on the front and large one on the rear, and remember, front is your ranges , then rear is to fine tune. No one can tell you what gear you should be in, your legs will. Do not pedal backwards, always forward, and do not kitty corner your chain, ie, small gear to small gear and large to large, because it will stretch your chain (yes, chains stretch and then you have to replace. Use both brakes at the same time, just using the front will throw you, and the rear will only slow you down not stop you. It is just like a car, front brakes do most of the work. Good luck
Sep 25, 2010 | Cycling
Turbo R-24 Model Empire 24 Inch Men&s Bike how many if any gears does it have shows to have ◦Shifters: Shimano tourney index but what does this mean. Sears can't answer
Count the number of sprockets you have up front, then count the number you have in the rear, Multiply, 3 x 6 = 18 speeds. 3 up front, 6 in the rear, or 2 up front, 5 in the rear, 10 speed. Etc, they go as high as 21. You might only have one in the front.
To shift, you have to be peddling, get the bike going, put the chain on the middle or the biggest sprocket in the front, move the left thumb shifter to do this, do not let the chain rattle, make it a clean shift and don't let it klik or rub. Then put the chain on the biggest one in the rear , without any rubbing, chattering, slipping, etc,with the right shifter, now you are ready to take off easily, when you get going and the pedals get too easy and go faster, shift the rear to the next sprocket down, then again, then when you are coming to a stop, down shift the rear sprocket back to the biggest gear and you will be ready to take off again easily. A few tries, you will shifting like mario andretti. Hope this helps.
Jun 16, 2010 | Empire Turbo TURBO BICYCLE R-24 MODEL...
How to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
May 03, 2010 | Cycling
Had to replace cable on grip shifters on a Huffy
if u buy a new grip shifter it comes with a diagram a bicycle shop might help
Jul 14, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
GRIP SHIFTERS WILL NOT TWIST WHILE TRYING TO SHIFT
This is likely because either a) the cable leading from the shifter to the part you are pulling is seized or b) the shifter itself is seized or c) both are seized. You would have to undo the cable from the rear deraileur, pull the inside cable out from the casing from top to bottom. Check it and see if it is rusted or full of crud. Give it a cleaning and spray some light lube down the outer (black) cables, then reinsert the cable. While the cable is undone, it wouldn't hurt to see if you can twist the grip shifters. If they are still tight, then get some lube in the grip shift. Also make sure the rubber grips are not too tight against the shifter. Hope that helps...
Mar 23, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Huffy Alpine 24 Youth All-Terrain Bicycle Logo
837 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
