Question about EuroTech 24 in. EDW154E Built-in Dishwasher
I worked before, after a reinstal the water does not fill. after about a while the display states er1 I cannot find access to the base pan as to remove any possible water.
  • MV_ATL Aug 10, 2013
    I have same problem and the answer below is not applicable - problem is FILL not drain. After a repair (replacing thermistor), which required the tech putting dishwaser upside down and disassembling, then reinstalling in cabinet, I get ER1 and it won't fill.
  • MV_ATL Aug 29, 2013
    Turned out the FLOAT was dislodged during reinstallation. Once set in place fill worked properly again.
  • 3 Answers
MV_ATL I had same problem - turned out the FLOAT was dislodged during reinstallation. Once set in place the fill worked properly again.
Posted on Aug 29, 2013
  • 64 Answers
Just tip forward and drain the water
Posted on Jul 14, 2009
I'm getting an E:15 on my new Bosch dishwasher and nothing works, how do I fix it?
E15 means that water has gotten into the base pan below the dishwasher and it is now in flood mode. You've probably noticed that the drain pump will run all the time now as well. What that means is that water has worked it's way down into the base pan below the dishwasher tub causing the unit to do nothing but drain. This is normally caused by the drain being clogged or too many suds in the tub causing the tub to overflow a bit. Either way, you'll need to uninstall the dishwasher and tip it forward at a 45 degree angle to drain the water out of the base pan. Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and pour a gallon of water in the dishwasher. If it drains it out right away and doesn't wash or refill, you still have water left in the base pan to try again, otherwise you're good to go.
Now if you don't want to do all this work just to get your dishwasher working again and you have time, let the dishwasher just sit unused for a week and the water in the base pan will evaporate as time goes on and the dishwasher will start working again after a week.
Sep 23, 2017 | Bosch Dishwashers
Motor runs with door open. No water in pan.
Sounds to me like there may be water in the moisture sensor. Your dishwasher is probably leaking and the noise you hear is the drain pump activated.
Apr 02, 2015 | Bosch SHV46C03 Built-in Dishwasher
My goodman ac is leaking at the base in my basement. The technician filled the freon R22 and it is still leaking water at the base. Checked the pump and it is working. No clogged or blockage. Please if...
put a level across the top of air handler you may find its leaning away from the drain. your pan primary outlet may have rust or slime blockage permitting some condensation to make it out to your pump but not enough to keep up with whats being generated by the evap coil. the pan may have rotted out if it has a metal one. some plastic pans crack from stress. if the coil has been removed and reinstalled the guide clips on the pan may me misalifned so your pan may not drain before it overflows. wetness there means you probably have moisture or waterbuild up in the ductboard liner for the return. i have removed 20 gallons of water from inside the box before with no indication it was wet until the airhandler was removed and i could see inside it. assess your drain outlets and pan issues by removing the front panels with a 5/16 nut druver. hope this helps.
Jul 20, 2013 | Heating & Cooling
My Beko DW686 Dishwasher displays ER1 Error Code, there are no error codes in the manual, can you help?
reset error code 01. pulled dishwasher out removed kick plate tipped at 45 deg angle and found no leaks or water. turn6ff59c77-7c20-45c4-ac2a-e3c9e6fd4c14.gif breaker off and back on after 20 minutes still doesn't clear.
see tje diagram attached. God bless you
May 25, 2013 | Dishwashers
My Blomberg dishwasher wont stop drain cycle
A common cause of this condition results from water in the base pan. This may result from a leak in the dishwasher or the drain hose (to the sink drain) backing up. First check the base pan (the very bottom assembly that all other components are mounted within) for any moisture - this can be difficult as there are only narrow openings between the tank and the base pan; a mirror can help or you might have to pull the unit out from the cabinet to access the sides. If there is moisture in the pan this problem must be corrected as the unit is just trying to protect against water damage from a leak. If the base pan assembly is dry, look at the float assembly (behind the water fill valve) as insects or rodents can sometimes interfere with the proper operation of this sensor. That causes the control to think there is a water leak. When this fault occurs everything is turned off and the drain pump runs continuously to eliminate any water from inside the dishwasher.
Apr 06, 2013 | Blomberg DWT14210
PUMP KEEPS RUNNING
Some modules have a flood safety in the base, if you have a leak (leaky valve, hole in door gasket etc) the base pan has a disc that floats and operate a microswitch and all the machine will do is pump ( you mat get a fault code displayed or flashing lights). Pull the machine forward on to large towel and tip it forward (pull from the back so it is sitting only on its front feet) if water seeps from underneath this will be the problem. If this is the case, you may find that the machine will start to work again, you will have to trace the leak or the float will just activate when the base pan fills again. Hope this helps, if you need any further assistance please add comment.
Mar 13, 2013 | Bosch Washing Machines
I have an asko d3251 dishwasher that won't stop running. The device in the drain that spins won't stop. I had to shut the power off to the unit.
Our unit had leaking connection on outlet side of fill solenoid valve. Any leak will cause water to accumulate in base pan. there is a float switch in base pan as a safety mechanism when water is in pan it causes a styrofoam float to rise and make contact with switch. This tells machine there is a leak creates error code to run pump continuously until water is removed from base. Disconnet electric from unit first. you must pull dishwasher out to get at back panel. Remove lower back panel to get access to mechanicals of unit. Once you remove panel you should see water in pan. If you see water that is most likely same issue we had. soak up excess water or tilt unit to drain water out of pan. once water is gone unit should start normally. If you look underneath while unit starts up - don't touch anything while unit is connected to electricity! You should notice where water is coming from. Our unit leaked at hose connection from outlet side of solenoid fill valve. connector is a plastic cam-lock fitting with a flow sensor integrated into it. there is an o-ring between the two parts. it comes apart with a very small amount of counter-clockwise motion. perhaps only five or ten degrees of indexing and it falls right off. it is a very flimsy connection for the main water line. the o-ring on our unit Was slightly deformed and not seated correctly. could have been from original installers 4 years earlier! Asko needs to re-design this part. I replaced o-ring and unit is working again however I do not trust that this fitting will hold up over time. Very poor design in my opinion. Other design flaw I noticed while looking at mechanicals is circulating pump isolation mount is not in correct location for pump motor. rubber mount is stressed to the point of almost tearing off! No way for me to correct this since location of mount does not match position of motor. We will not replace this unit with another ASKO when it goes.
Jan 19, 2013 | Asko D3251HDSS Stainless Steel Built-in...
I have a asko dw20.1 dishwasher. When i turn it on the machine pump the water out, then it take new water in, and then it just stops? help..?
HI,
You either have a diverter problem or the unit can not determine how much water entered the tank on fill. Are you able to access base pan area? If so, is there water in the base pan? This is important to determine what your next move should be. If water is in the base pan, need to look at diverter under pump housing, look for water residue, this will tell you is the diverter has jammed or is leaking. I hope this helps.. Also around the door handle of the dishwasher door, you will find the model number like 3250, or something like that. With that number I can lead you in parts locating and problems related to yours model.
Looking forward to helping you..
Aug 03, 2011 | Dishwashers
Dishwasher: BOSCH SHE43 - pump keeps draining
Your dishwasher is stuck in flood mode. Bosch dishwashers are built with flood switches located in the bottom base pan of the dishwasher. The flood switch is connected to a rod that activates a small interlock switch. When water enters the base pan on a Bosch dishwasher, a Styrofoam puck lifts the rod, activating the flood switch.
When the flood switch is activated, the dishwasher will go into a no-fill, only-drain mode. The drain motor may also run with the door open to the unit. This is definitely a sign there is water in the base pan. This can be caused by the drain being clogged. There are two ways to fix:
1. You can uninstall the dishwasher and tip it forward to about a 45 degree angle to drain the water out of the base pan. (This is probably why Ian Bint's solution fixed the problem.) Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and begin a cycle. If it fills and runs, you are good to go.
2. You can also unplug the unit, then remove the kick panel at the bottom in the front. (It's attached with two screws.) Then get some old washcloths or small towels and reach into the base pan below the dishwasher to soak up the water. The pan is directly behind the plastic base panel rim. Once the pan is empty and dry, your dishwasher will no longer be in "flood mode" and will run properly.
If the base pan keeps refilling with water and the no-fill problem returns, there is definitely another issue, such as a clogged drain. At this point, you need to decide whether to invest in an expert evaluation by a certified Bosch repairman and make the necessary repairs, or buy a new dishwasher.
Jun 28, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Apr 28, 2008 | Ruud UBHC Air Conditioner
EuroTech 24 in. EDW154E Built-in Dishwasher Logo
143 people viewed this question
Top EuroTech Dishwashers Experts
Tony Houde
Tony Houde
Tom Chichester
Dave Glabb
Are you an EuroTech Dishwasher Expert? Answer questions, earn points and help others
