Question about Amana NGD7200TW Gas Dryer
Dryer is taking several cycles to dry clothes.
  • 230 Answers
Very common problem. You need to call a duct cleaning company and tell them to clean your dryer vent. Rule-of-thumb: dryer vents should be cleaned every couple of years to prevent them from being clogged with lint and causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is to go outside where the vent exits the house and feel the air-flow. should have adequate air-flow.
Posted on Jul 15, 2009
jsrock516
  • 5911 Answers
SOURCE: roper clothes dryer not drying clothes
Please take a look at the following link. In particular, the first major paragraph where it discusses proper ventilation:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
I know the link is for a dryer that no longer heats, but if a dryer is left in a condition where it is starved for air, the heating circuits will actually over-heat and eventually fail. You need to ask yourself when was the last time you inspected or cleaned the dryer exhaust ventilation. If you can't remember, or if you've never cleaned anything before, it may be a good time to do so. Most dryer heat related problems are caused by poor ventilation and lack of cleaning. I recommend that you clean the dryer ducting twice a year. That's once in the spring, and once again in the fall. It is also important to note that the SHORTER and STRAIGHTER the exhaust vent line is, the BETTER. The more bends and kinks that you put in the dryer exhaust, the more resistance you create for the dyrer blower, and the more potential choke points you create where lint can accumulate and clog. Not to mention, this can also cause a fire hazard and/or a habitat for rodents.
Follow the recommended advice and try drying a load of clothes with the vent hose removed, first. If your clothes dry faster like they should, you may have an exhaust clog somewhere. If your clothes still aren't drying correctly, inspect the interior blower fan housing for obstructions. This is all explained in the link provided.
If you attempt these preliminary measures and still have problems, please let me know. I hope you find this information helpful.
Posted on Sep 04, 2008
SOURCE: Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Posted on Oct 05, 2008
rickzilla
  • 706 Answers
SOURCE: Gas dryer not completely drying clothes
Hello br4noles,
based on your description, you may have one of several problems but the prime suspect would be a restrictive exhaust system. Check and make sure you don't have a blockage in your vent system all the way from the dryer to the exit point. When cycling, you should have a fairly robust air flow at the exit outside. If you don't, then you may have a blockage in your vent, something restricting the blower from operating at 100% or lastly a poor flame from your gas system. Air movement is the key thou so I would focus on that since you didn't state that the dryer wasn't heating up.
Regards,
Rick
Posted on Nov 25, 2008
  • 77 Answers
SOURCE: Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
Posted on May 12, 2009
KevinWhite
  • 1902 Answers
SOURCE: My LG TROMM Dryer is not heating up and it takes
Hello & Welcome to FixYa
If everything else in the dryer is working fine and it won't heat so it means that the thermal fuse which is located inside the rear panel on the blower wheel housing is bad and needs replacement. Please get back to me if you have any other questions.
Posted on Dec 02, 2010
Clothes not drying. Dryer feels hot but clothes remain damp through several cycles.
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 28, 2010 | Whirlpool Dryers
No Heat: The dryer has been taking more than one cycle to dry the clothes for several months, but today there was a very small load in the dryer and it took 4 cycles to just get dry enough to take out of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 12, 2010 | Dryers
Heats up but takes several cycles to get clothes dryer
Check for a restriction in your exhaust vent. not just behind the machine but all the way to the outside vent,should have good warm airflow at outside vent. With no good air flow you have no way to get rid of the moisture. and all you will end up with is warm moist clothes. this can happen slowley happen over time and next thing you know it takes several cycles to dry the clothes .it cost a lot to dry them this way
Aug 08, 2010 | Amana NED5400TQ Electric Dryer
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
May 12, 2009 | Maytag Dryers
Dryer gets hot spins takes several cycles to dry fully
ahhh very common, clean clean clean inside the dryer, take the lint screen put some toliet bowl cleaner on it let it sit while you are tearing the dryer apart and clean the whole dryer vent and or change it, make sure the flap outside is not stuck shut as well...
May 08, 2009 | Dryers
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Amana NGD7200TW Gas Dryer Logo
124 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
