Gas heater shuts off after about 3minutes and have clean filter rinnai rce-329h gas heater
I have a problem with what you are asking,, the numbers you have are for a fan convection ROOM heater,, does the fan come on within this 3 minutes of running, if not it could be over heating and shutting down on a safety, if it does the thermostat could be bad and it is reaching the desired temp and shutting off like it shoud,, check the thermostat to make sure it is working properly,, set it at it's lowest temp turn on the unit have a themometer infront of the air flow see if the temp is the same as the setting,, how old is this unit, it may just be time to change with new,, if the controls are bad this unit sells for about 600 and to replace these parts is about 400, go to there web site,, write back and let me know how it goes,, good luck
