Question about i-mate JAM Pocket PC
Lost contact details
Telstra service person took my battery out to "fix" my i-mate and I lost all contact details. I do not have a back up. Is there any way of retrieving the data? SIM card has only part of data and each name will 3 or 4 different numbers ie. mobila, home and work and each was copied back like that.
    Problem Solver:
  • 5 Answers
Re: lost contact details
Pda(pocket pc) recovery softwares available on net try them
Posted on Nov 24, 2007
0 characters
3 Points
I have lost my test message icon on my blackberry curve 9360 how do i get it back
My wife's 9360 just did the same thing, the message icon vanished. I took the battery out for ten seconds and that fixed it. Hope this helps. Jim
Dec 13, 2011 | RIM PDAs
How to back up contacts and personal files on i-mate Jam-in?
for contacts u should copy them to ur sim card but for files u should use a memory card or computer
Feb 18, 2010 | i-mate JAMin Smartphone
Battery Problem and signal problem
You will find that o2(i-mate) is often branded as a HTC. You may wish to try the following links to find your local service agent.
HTC Product Support - Drivers, FAQ etc
HTC Offcial India Website
Best of luck solving your battery/signal issue!
May 21, 2009 | i-mate PDA2k Pocket PC
Restore information
I can understand you very well since I use a PDA also and this battery problem is an issue for me too. I assume that your backup file is in your storage card and is a standalone exe file (means you don't need your backup software being installed first to start a recovery process). You can remove your storage card from your PDA first and back it up to a PC to ensure that your only backup file is safe. Next, you can do another hard reset to your PDA and do all the settings steps again. After that, you can try to recover some of your data by starting the recovery process and performing not a full backup, but just the necessary data first. I am recommending this step because you have a PDA that's main storage area is very limited (like mine) and if you are normally using it filled up, backup process can be terminated before it finishes because of the backup file is nearly equal to the total main storage area,  and this causes your device to stop working even after your incomplete recovering process. This is mainly becuase recovering process needs lots of space and when the process is near the end, it can't have enough space on main storage area to continue. So, you can try to recover the necessary data first (Softwares, contacts, appointments, ...), then, if it is successfull, you can open your backup file again and this time you can select the other personal documents that has been left in the first process. (I hope your backup software supports selecting the needed data to recover.)
Apr 13, 2009 | i-mate Pocket PC
My i mate wont go pass the home page when u turn it on please help me it just shows telstra imate
do a hard reset
to do a hard reset just hold the power button and press the in the hole(near the head phone jack)for 6 secods
Sep 13, 2008 | i-mate JAM Pocket PC
Not able to view incoming call details
Do you have those options activated from your service provider? Usually is a $ cost to have those activated on your monthly plan.
Pay as you go usually do not have that option.
Mar 05, 2008 | HTC Touch P3450 Smartphone
Unlocking imei number on imate jam
is telstra is a network provider if so the IMEI is your phone ID no. so you can't change it and there is no lock from your phone can do this ,  try to get help from the network provider
Nov 23, 2007 | i-mate JAM Pocket PC
Lost Contacts.
Your initial settings may have been lost if you didn't back them up in an mmc card using the top slot compartment of the phone sorry! Whenever you remove your battery from the phone for more than 2-3 mins the phone goes to a default reset mode and on start up will start to re-install all the default features including the Arabizer which is due to the fact that the phone was designed in the UAE,you however can reject this installation whenever your default startup commences,and still enjoy your phone.
If you have an mmc card then after the phone has fully rebooted at default settings. Go to the phone settings page and select the "phone backup" option this enables a restore or backup option.If you have already backed up the data before, click on restore.All your settings will be restored.If not you will need to make new settings for your phone and then back them up this time.
Also for your phone contacts there is a "permanent restore option" at the "Phone settings" display. click on this option after you have entered your phone details and it will permanently save all your phone nos regardless of any kind of reset.If you did'nt do this earlier i'm sorry,your phone nos are lost also.
Oct 09, 2007 | i-mate PDA2k Pocket PC
i-mate JAM Pocket PC Logo
44 people viewed this question
Top i-mate PDAs Experts
Martin Murray
bharat patel
Are you an i-mate PDA Expert? Answer questions, earn points and help others
