Question about Microsoft Xbox 360 Console
My xbox 360 turns on, has sound but does not display a picture and it is on the correct channel.
  • 767 Answers
Good, you check all the video out / in and tv setting is right .
The problem is, under the G.P.U. there's a hot spot , and it just so happens
to be adjacent to the video buffer out connection , which has broken free from the main board.
No red lights , everything sounds good but no picture . solution X clamp mode ,done right of course.
will reestablish the video and prevent additional erreor . if you have any questions fell free to email me
Repairtech
Posted on Jul 13, 2009
5 Suggested Answers
  • 44 Answers
SOURCE: my xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Posted on May 14, 2008
SOURCE: xbox 360 sound but no picture
ARE YOU PLAYING YOUR 360 ON A REGULAR TV?
Posted on Nov 08, 2008
Neniv
  • 12 Answers
SOURCE: there is no picture when i turn the xbox 360 on, i
If the 360 is connected using component cables, check to see whether the switch on the part that plugs into the Xbox is set to the correct format you need to output in.
Posted on Nov 28, 2009
  • 60 Answers
SOURCE: Xbox 360 Console: xbox 360 video not displaying but sounds works...
make sure the color cables a fastened tightly in the t.v.
Posted on May 23, 2010
My sounds works and so does my directtv but no picture will show up for my 360 i bought a new av cord and it still wont work how do i fix it
Are you on the correct channel or input for the xbox 360? Also check your av cable to see if it is on the hdtv or regular tv. You can move the switch to make the adjustment. It may be how you have set up your xbox 360 cables and the directv box cables to the tv so you should consult your tv manufactory for the correct guide on setup.
Dec 22, 2010 | Microsoft Xbox 360 Console
No picture for xbox 360
is this a brand new console? check the switch on the video cable
Jul 11, 2010 | Microsoft Xbox 360 Console
I have no picture but hear the sound of the system on my tv
It could be 3 things:
Your tv connections are disconnected and need to be replaced. See if anything else works when plugged into these connections.
Your cable cord could have a disconnect internally and the cord needs replaced.
Your graphics card on you XBOX 360 is shot any you need to replace it.
Good luck and please rate my solution accordingly.
V/r,
Coldissickofman
Jan 23, 2010 | Microsoft Xbox 360 Console
Xbox picture wont come up on tv
Firstly (i know it might sound silly) but is your video cable set to composite or HDTV? If that isnt the problem, your video encoder chip at the back probably has cracked or stressed solder joints that will need resoldering at the correct temperature with a special heat station.
Give us a call if you need help doing it.
FixMyConsole
May 20, 2009 | Microsoft Xbox 360 Elite Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
XBOX 360 NO PICTURE
if using hd tv then use the cable with the blue lead, if not using hd tv then use the red, white and yellow leads. If using the scart connection to put the leads into make sure that you have it set to the correct av or ext channel
Dec 28, 2008 | Video Game Consoles & Games
Xbox 360 sound but no picture
Nov 08, 2008 | Microsoft Xbox 360 Console
Xbox 360
Try turning the xbox on and pressing the TV/Video button on the tv or remote a few times and see if the picture comes up.
Sep 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
116 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
