Question about KitchenAid Refrigerators
Fridge not cooling, motor constantly running
Hello, I have a KSRS251. About 1 year ago, the starter relay went out (troubleshooting let me to this solution), and that fixed it. This unit is about 8 years old, and a friend told me I should probably change the capacitor as well. I did this a few months ago.Today, I notice the fridge not cooling properly. I noticed the fridge was running a lot, and no cooling. I think I found it shortly after the failure since everything was still relatively cold, but I have thermometers in both the freezer and the fridge, and they were both reading high.Could the relay be bad again?The replacement relay the first time was 2 pieces: a piece about 1'' x 1/2'' x 1/2'' which connected to 2 pins on the compressor. The other piece was relatively flat, and hooked to the 3rd pin. That flat piece does rattle when I shake it.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Sounds like low on Freon find the evaporator up in freezer hiding behind back wall or under freezer floor. when removed look at the frost pattern if it is only partial covered in frost , good chance it needs a shot of gas Freon like stuff gas. not sure in your areas what requirements costly in The Great White North. But if there is only a great block of ice from four my best seen it started right where the door panel ends and freezer began 36 hours to defrost. So if ice cube is what greets you Defrost Problems check Defrost timer stuck, Defrost thermostat, Defrost Element, check all wiring in freezer were the last 2 are located.
Posted on Mar 18, 2017
SOURCE: Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Posted on Dec 10, 2007
  • 1314 Answers
SOURCE: FRIGIDAIRE FRS20ZRGD7 (SIDE BY SIDE) WARM FRIDGE/ COLD FREEZER HELP!
look open the freezer door pull the lower kick plate off look for a small little hole there its a mechanical timer model should be close to the wheel in that hole will be a plastic piece open the freezer door you will hear the fan running in the freezer take out the four or five screws on the lower panel where you keep seeing the frost and remove it you will see a silver honeycomb looking piece that's the evaporator on one of the tubes will be clipped a silver dome looking piece with two wires on it that's the defrost thermostat now turn the timer with a screwdriver that's the piece in the little hole slowly to your right till you hear a click and the fan stops in the freezer now as your turning it it will make a ratchet sound you want the click and the fan to stop look at your watch and note the time then wait about 5 minutes and look at the heater to see if its on if its all frosted up the frosted should look all watery if the heater is on then just let it run if not then reach up and turn the freezer control to the off position then un plug the two wires on the defrost thermostat and take the two wires that you unplugged the thermostat from and plug them back together and turn the freezer control back on and wait stay there and watch the heater come on let it defrost the evaporator if the heater comes on when you do that .that means the thermostat is bad if the heater comes on without you having to by pass it that means the timer is bad if you do all that and the heater does not come on then the heater element is bad now its going to get red like an oven and pop and sizzle but don't let it freak you out now if you had to by pass the thermostat and the timer cuts the compressor on before the frost is all clear just turn the timer around again till the fan cuts off and the heater will come back on if you by passed the thermostat then when all the frost is melted then reach up and turn the freezer control back off and reconnect the thermostat.Now after about 30 mins after turning it off the timer should cut back on if its not bad when you change the timer back out the two screws reach under the fridge and turn the timer and its shield till the screws are in the removal position when the timer is loose remove the shield and unplug the timer plug your new one back in then put the shield back on and back where it goes now id recommend changing both the timer and the thermostat as they fail pretty close together the stuff i described above is to make the unit defrost to save your food with out having to use your hair dryer also when all the frost is melted at he bottom of the evaporator on the right hand side is a hole in the cabinet that has to be clear of frost for the fridge to cool properly now any time during this defrost technique if you have a problem turning off the freezer cold control will turn off the defrost system1.gif too if i can be of help or you need to know something just reply to this post
Posted on Mar 30, 2008
skotkolr
  • 558 Answers
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
Posted on May 27, 2008
  • 161 Answers
SOURCE: temperature rising in fridge and freezer
Yes this could be the problem. I would need more information to believe differently.
Posted on Jul 04, 2008
SOURCE: kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Posted on Feb 01, 2009
Hi there bassically starter motor continues to spin while engine is running i changed the starter motor about a month ago because i thought that was the problem it seemed to work for the last month and it...
The start relay is sticking or is getting a close signal from a wire that is shorted. This is easy to troubleshoot by pulling the relay out of its socket and interrogating the socket terminals with a volt/ohmmeter. If you reply with model and year, I can provide the troubleshooting procedure.
Jul 12, 2017 | Ford Cars & Trucks
Doesn't cool
Hi.
Most common problems with refrigerator are either caused by a defective defrost system or by defective compressor motor assembly.
Check if the coils at the back are frozen. In that case the problem is the defrost system. Even if coils are not visibly frozen, try doing a complete defrost and see if the fridge will restart cooling. You can follow the troubleshooting that I just wrote on this page.
If problem is not the defrost system, check if the compressor is starting. If the compressor is not starting at all or is humming and slow to start, then you may need to replace the compressor starter kit or the compressor itself. The starter kit comprises a capacitor and a relay connected directly to the motor. The motor is usually under warranty for many years (up to 12). Call manufacturer if you think that the problem is the motor.
If the motor instead works, stays always on, and defrost has just been performed manually, then there may be insufficient gas pressure. This usually happens with old appliance and requires a repair call.
Modern refrigerators may also deliver insufficient cooling because of a defective ventilation (damper) system, or because of defective temperature electronic control. The most common faults occurring with all refrigerators are still fixed troubleshooting defrost system and compressor starter kit.
Regards.
Ginko
Aug 08, 2011 | Refrigerators
Motor sounds like it is running constantly and only shuts off when I open door? Fridge is 1 year old!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 20, 2010 | Samsung Refrigerators
2 yeaor old kenmore fridge not working, motor runs
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | Kenmore Refrigerators
Freezer is not working. was purchased less than a year ago
The entire refrigerator is still under warranty. I would call an authorized repairman.
If you still want to do some troubleshooting: Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 08, 2010 | GE Refrigerators
GE profile fridge - stopped cooling. All I hear is a clicking sound. 3 years old. What can I do?
How to check stuff>
If the relay is ok the compressor is the problem. It has a 5 year warranty.
Oct 29, 2009 | Refrigerators
Maytag french door fridge crapped out....again
buzzing sound comes from freezer fan or ice maker fan. They are located behind the freezer rear wall. These freezer fan cools the freezer and the refrigerator. The ice maker fan supply air to ice maker.
Jul 22, 2009 | Maytag MFD2560HES Bottom Freezer French...
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
First of all Give me model# and Serial#.
you will most likely have to replace main control board and evaporator fan motor. They have had a service bulletin out on this problem.
Jan 17, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
108 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
