Question about Sony Playstation 3 (PS3) Console
Ps3 wont load games
System got corrupt disk and from there wont load any games went through some stuff like system format etc etc nothing yet.
Try restoring your system (re-update, if necessary), or simply buy a new HD, it's cheap on ebay, must be a 2,5'' SATA 5400rpm .
Posted on Jul 12, 2009
  • 34 Answers
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
Hi,my ps3 is saying, the hard disk's file system is corrupted and will be restored. the it says press ok. after i press ok, then it says restoring the system, after that it restarts it goes back to the...
here's some ideas:
________________________
I fixed my ps3!! All you need is a friend with a ps3!! Swap the hdd's and boot up your friends ps3, format the hdd, put it back in your ps3 and you may need to format it again.
_______________________________________________________
I tried to fix my friend's PS3 HDD that way in mine...it still gave an error every time he booted up his PS3. At that point I stuck the PS3 HDD in my laptop, booted from a Windows CD and fully formatted it that way...stuck it back in his machine...used it to format....finally got his stuff going. Took a little extra time but no problems since.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
Hard disk corruption. says press x to resore but wont load past 18%
Try this:
turn on ps3 press x to restore on 0 % quickly pull out hdd. then wait may take up to an hour a message will come up to formate hdd. put hdd back in and press yes to format this process worked with in seconds for me but can take longer. it does work but you will lose all saved stuff but online stats will still be on the system. good luck hope it works for u to.
________________________________________________________
or this:
New fix (possibly), and it doesn't take a laptop or a friend's PS3 to do.
Simply remove the hard drive from your PS3, and turn on the console. It should display a screen saying the hard drive will need to be reformatted. Then, plug the hard drive back into your PS3, and allow it to reformat. Your save game data will be erased, but you should be able to use your PS3 again.
_________________________________________________________
whoever has a problem withe their ps3 needing to be reformatted just take out your hdd when the restore comes up, then press x, it will take a will before the ps3 tells u to insert a hdd to be formatted (took me 12 minutes)
good luck
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
Ps3 hard disk file is corrupted
This problem always happen when you switch off your console while it is saving data or reading data from the HDD, so your HDD file system damaged, in order to solve this problem you need an external SATA 2.5 hard disk case, extract your PS3 hard drive and insert it in the SATA 2.5 case, plug your hard dist to a computer, you will find that the whale hard disk is unallocated, so format it with FAT32 or NTFS using your computer, after that return your hard disk to your PS3 console, now, your PS3 console will recognize it, and it will ask you to format it, say YES!!... congratulation your PS3 console is working now
BUT REMEMBER THAT YOU WILL LOSE ALL YOUR DATA IN THE HARD DISK INCLUDING YOUR SAVES, IMAGES, MOVIES AND ALL YOUR STUFF
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
When we start the system we get message "This hard disk file system is corrupted and will be restored". If we hit O.K. it start to restore but nothing happens after that.
This problem always happen when you switch off your console while it is saving data or reading data from the HDD, so your HDD file system damaged, in order to solve this problem you need an external SATA 2.5 hard disk case, extract your PS3 hard drive and insert it in the SATA 2.5 case, plug your hard disk to a computer, you will find that the whale hard disk is unallocated, so format it with FAT32 or NTFS using your computer, after that return your hard disk to your PS3 console, now, your PS3 console will recognize it, and it will ask you to format it, say YES!!... congratulation your PS3 console is working now
If the above solution does not work you would have to buy a new HDD for your PS3
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont pull the disk into the player
prior to the issue u facing basically is improper shut down of ps3 causing the ps3 operating system corrupted .1)back up your save game and the rest.Then format hardisk then restore back up .It will help to improve this fault.good luck .visit you tube how to format ps3 and back up .Pls rate me.
Sep 21, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 wont play PS3 Games
ok right so your ps3 wont read disks huh well first of all id like to say this has happened to me twice and it has worked perfectly for me and i quarentee it will work for you ...
first save all your data to a memory stick
secondly go to settings, system settings, and format your ps3 by clicking on full format this will delete all your filles :( but will refresh your ps3
BTW this formatting thing will take atleast 4 hours so just leave your ps3 on and chill out watch t.v or something :)
hope this helps
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
Not finding harddrive
this happens when there is corrupted data on the hd.click yes and it will format the ps3 and it will work again.the only bad thing i that it will erase all your save games and game datas.better than nothing fix?
Dec 21, 2008 | Sony Playstation 3 (PS3) Console
When I switch on my PS3 it says that the hard disk is corrupted and to proceed to press OK. So I pressed OK and it loaded, turned itself off and the system restarted itself. But nothing seems to have...
you already have a corrupted hard disk.the best possible solution for that is to replace it with a new hard disk.corrupted hard disk causes the ps3 to freeze bcoz it cannot the load the data that the ps3 needs to boot properly.hope this one solves the problem
Dec 21, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
107 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
