Question about HP OfficeJet 4215 All-In-One InkJet Printer
How do i select printer when it is on fax - HP OfficeJet 4215 All-In-One InkJet Printer
    Habit-Forming:
  • 121 Answers
Put it off and on again,but most time this particular product comes on a ready on printer selection,so its only when you want to select anothe function you will need to select an option,if problem pesist,reset to factory setting.
Posted on Jul 13, 2009
  • Duke Bells Jul 13, 2009
How seup fax ring
Before selecting the ring to answer, under stand what it is..
Press Menu button, scroll to fax set up with help of arrow keys, press ok button, scroll to answering mode. Select desired "auto, manual, fax & tele/fax.
What are these?
Auto: Auto aromatically tele mode will coverts in to fax mode irrespective of selected ring count. suppose if ring count selected as 4, printer will ring 4 times then stops ringing & converts in to fax mode. It doesn't matter whether it's telephone or fax.
Manual: Printer always telephone mode. To convert in to fax mode, need to press fax button while ringing.
Tele/Fax: Printer detects the incoming call type as tele(analog)or fax(digital) accordingly its will act. If its fax , line converts in fax mode with out any ring(silent detection), prints the received fax.If its telephone,printer rings as tele phone.
* In auto mode only you need to select desired ring to answer(2-6 rings)
There fore first you need to select "auto"mode, then scroll to ring to answer, press ok then select desired ring count, press ok to confirm..
Aug 23, 2014 | HP LaserJet 3050 All-In-One Printer
Dell V715w wont receive faxes
To receive a fax automatically:
  1. On the printer control panel, press the Setup setup_icon%281%29.jpg button, then use the menu to select Fax Setup, Ringing and Answering, and then Auto Answer.
  2. Select On and then press OK to save the settings.
  3. Select Pick Up On and set the number of rings, then press OK to save the settings.
To receive a fax manually:
  2. Select Off and then press OK to save the settings.
  3. When the telephone rings and you hear fax tones when you pick up the handset, press the Start button on the printer or *9* on the telephone attached to the printer.
Oct 25, 2011 | Dell All-in-One Multifunctional (v715w)...
I get a remote fax error when trying to send a fax...i have a Lexmark X5070 all in one printer/fax
The problem could be due to the quality of the telephone line connection. Try to resend the fax.
Lower the transmission speed. Follow the steps below:
  1. From the printer operator panel, press Fax mode.
  2. Press the menu button.
  3. Select Fax Setup.
  4. Select Dialing and Sending.
  5. Select Max Send Speed.
  6. Lower the speed to 9600 bps.
  7. Press check button.
Try to send a fax to verify that the problem is fixed.
Sep 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
How can I cancel incoming fax on lexmar x646e
If the printer is connected to a network, get the IP address of the printer and access printers web interface. You may print a network settings page to get the IP address of your printer. Open a web browser and type the IP address on the address bar.
On the left side, click on the configuration menu and click on fax settings and select fax setup. Under fax receive settings, please uncheck enable fax receive.
You may also do this using the printer's operator panel. Just press on Menu button and select settings. Select fax settings and analog fax set up. Select fax receive settings and turn off enable fax receive then press submit.
Jun 20, 2011 | Lexmark X646e All-In-One Laser Printer
How do you load a lexmark X5650 all in one printer, copy, photo, scan, and fax? I am trying to figure out how to load the fax to send the fax to someone.
Sending a fax using the printer control panel:
  1. Make sure the printer is on and is connected to a working phone line.
  2. Load an original document faceup into the Automatic Document Feeder (ADF) or facedown on the
    scanner glass.
  3. From the printer control panel, press the Fax button.
  4. Enter a fax number, or press Address Book to select a number from the Speed Dial or Group Dial list.
  5. Press Color or Black to select a color or black-and-white fax.
  6. Press Start to send the fax job.
Source: Lexmark 5600-6600 Series Fax Guide
May 06, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How do I receive a Fax on a J3680
1- Connect the telephone cable shipped with the printer to LINE-1 of printer and telephone wall jack
2- On printer press Setup(wrench) button >>>> select Advanced Fax Setup >>>> select ECM (error correction mode) >>>> select "off" >>>> press OK
3- On printer press Setup(wrench) button >>>> select Advanced Fax Setup >>>> select Fax Speed >>>> select "slow" >>>> press OK
4- On printer press Setup(wrench) button >>>> select Basic Fax Setup >>>> select Rings to Answer >>>> select 6 >>>> press OK
5- Make sure auto-answer is turned on.
6- Request a friend to send you a fax
Wish for all success..
Dec 22, 2010 | HP Officejet J3680 Multifunction Printer...
Install fax machine
First Check the Phone Line That would be connected at the back of the printer ; it should be Two prong i.e. check at the tip of the phone line that is connected at the back of the printer there should be 2 copper wire strip.
Connect it at the back of the printer which says Line 1 ;
Press the "Setup" button(Symbol of a Monkey Range)
Press the Right Arrow key and look for Bsic Fax setup Press OK
Look for Fax header press ok
Enter your Name Select Done
Enter you Fax no. Select Done
Look for Rings to answer Press OK
Make it 2 If its a dedicated fax line
Or, Make it 6 if you use it with phone and use an Answering Machine
Get back to the previous menu and Look for Advanced Fax Settings Press ok
Select Distictive Ring pattern press ok
Select if you have one otherwise Select ALL Rings Press Ok
Under DRP look for ECM : make it OFF
Under ECM look for FAx speed : make it medium
IF you have Voice mail you may not recieve fax ; cannot use fax on vonage line
Try to Fax this should Work;
Sep 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My fax is trying to forward to another number. How do I get the forward off of the menu
To use/emable/disable fax forwarding 1. On the all-in-one control panel, press Menu. 2. Use the < or the > button to select Fax setup, and then press . 3. Use the < or the > button to select Fax Recv. setup, and then press . 4. Use the < or the > button to select Forward fax, and then press . 5. Press the > button to select On or Off, and then press . 6. If you turn on the fax-forwarding feature, use the alphanumeric buttons to specify the fax number where the fax is to be sent, and then press to save your selection.
Jun 03, 2009 | HP LaserJet 3050 All-In-One Printer
Not able to recieve fax
Note u will be losing all our faxes stored in memory and contacts...
Disconnect the power cable from the back of the printer.
Hold down the Stop/Clear button.
While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
Select the personal settings you require as follows:
LANGUAGE? Press the right arrow key to select the language you want to use, and then press Select.
COUNTRY CODE: Press the right arrow key to select the country you will be using the printer in, and press Select.
ENTER DATE: Using the date format dd/mm/yy (in the USA, mm/dd/yy), press Select.
ENTER TIME: Using the format hh:mm, press Select.
Select Format: Press the appropriate number to choose between 1=12hr, 2=24hr.
PERSONALIZE FAX: Press Select.
Enter Name: Type in the name and press Select.
Enter Fax Number: Type in the number of the phone line to which the printer will be connected, and then press Select.
Feb 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
