Question about Whirlpool Calypso GVW9959K Top Load Washer
Tears up fluffy towels
This machine will pull the threads out of regular fluffy towels. you have to get flat towels.
  • 15,935 Answers
Check the nunator for burrs. Run an old set op pantyhose around the inside of the drum to see if you can find/catch the snagging point.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Please adviseWashing towels. I have tried every recommendation to try and keep the towels soft and fluffy. All to no avail. The towels come out hard and "scratchy".
The most common reason why your towels are hard to scratchy because there are low grade Walmart a good quality tile will do you need to purchase better quality don't play the washing machine you need to buy a better quality towel
Feb 12, 2018 | Washing Machines
How to clean my fluffies?
Just follow these steps:
STEP 1: Soak you Dirty Fluffies
STEP 2: Wash them on a regular setting, in cold or warm water in washing machine.
STEP 3: Brush out your Fluffy
STEP 4: Hang your fluffies up to air dry.
STEP 5: Once your fluffies are nice and dry, you'll have to brush them out one more time to really bring them back to 100%.
STEP 6: Enjoy Your like-new FLUFFIES!
For more details about any Rave outfits, you can visit:
Rave Clothing and Festival Fashion RaveReady
Jan 11, 2017 | Washing Machines
I have Hoover 700 LA, Why does it pull threads from my towels?
Machines do not pull towel threads. However, old towels have weakened fibers that will fall apart under the stress of being washed.
And if you use bleach in your wash, that is an excellent way of deteriorating fabrics for premature departure. Yes, it disinfects but it comes at a price.
Aug 24, 2015 | Hoover Washing Machines
How can I keep my bath towels soft?
I also like fluffy and soft bath towels, I recommend that you check out this article with some really great tips for keeping towel soft and fluffy.
Sep 17, 2013 | Home
How do I set up my babylock serger for a rolled hem? What is the tension to be set at?
I don't know your babylock well, some of these have automatic tensions and electronic stitch selection. But a rolled hem is achieved on any overlocker in the following way; the actual dials and knobs might vary a bit.
Firstly there is a stitch finger that you need to change or retract so that the thread can roll the fabric rather than staying flat. For a normal seam this finger sticks out in the area where the loopers and needle form the stitch holding the cut edge flat until the seam is made over it. But for rolled hems you want to retract this finger so it does roll.
On the Bernettes this is a little lever in front of the stitching area that you pull back to retract the finger. Have a look around where the stitch forms and you should see the finger. Some machines, its a part you change on the needle plate with a screw driver, or just move a switch or lever.
You want the right hand needle in place, remove the left hand needle.
Thread upper looper with wooly overlock thread, this is a fluffy nylon that pulls flat under tension but relaxes and "fills" out once its stitched into place. Gives that lovely covered look you see on shop bought tablecloth edges. Your regular thread in needle and lower looper. Usually cutting blade to the right side as you want it to cut more fabric than in the seam so it rolls under. Now loosen off the tension on the top looper, (I use 2 on mine but this is something you need to finesse with each machine), and tighten up the tension on lower looper, (about 7). Leave needle tension alone.
Now test stitch on your fabric, and finess the upper and lower looper tensions until you get the lower looper thread almost not showing, it should be right up against the needle on the underside with the upper looper thread completely wrapping around top and bottom, pulling the fabric under.a seam like this.
Test stitch and adjust upper and lower looper until this is happening.
Now, turn stitch length down to close up the stitching, probably 1 or 0.8 if you want a real satin stitch look to the hem.
Because of the stitch density this uses thread so do the finessing first, then turn the length down.
That's it! Now right down the tension settings you used and keep handy for next time.
Sep 24, 2011 | Baby Lock Eclipse Serger
Embroidery bobbin problems.
Each manufacturer have their own bobbins.......not interchangable
Apr 28, 2009 | Baby Lock Sewing Machines
Pulled threads
THAT'S NOT THE WASHER'S FAULT. MAYBE TRY TO WASH ON DELICATE CYCLE
Apr 07, 2009 | Kenmore 15864/15862 Top Load Washer
Whirlpool calypso
the calypso washer is much older then 2 years. they stopped making them quite a few years ago. what you are seeing is how towels will come apart when washed with an aggressive washer. even expensive towels can be poorly sewn and will come apart when washed too hard. i might suggest you use the light cycle as it has a slower washing cycle speed. if you check your older and "better" towels are not doing the same thing as your new towels. i know its not fair but it is the way towels are now. you can try to remove the threads that are coming off your newer towels and then all should be ok, but there is nothing wrong with your washer just the way towels are now.
Jan 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Can't get top thread to pull up bobbin thread on my sewing machine
Try the regular first steps of change the needle make sure the flat side of the needle goes to the back and is all the way in. From there try rethreading the machine from scratch. If none of these work it may be the timing from the needle to the hook of the machine but start easy first.
Aug 26, 2008 | Sewing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
