Question about Olympus Camedia D-360L Digital Camera
Camera turns on beeps turns off
I have an olympus fe-360. when iturn the camera on the lens comes out it beeps then shuts off.
  • 73 Answers
Hi there. Turn on. Before it beeps, take the battery's out. This may take some practice. Now us a Qtip almost soaked in rubbing alcohol and clean the outside edges of the lenses. Put battery's back in and cycle the camera on and off. I hope this works for you. It worked for me.
Thanks
Paul
Posted on Jul 13, 2009
Olympus FE-360...All of a sudden when I take a picture, the picture comes out way to bright. I tried turning the flash off and same problem...The picture is just a big flash
This might sound dumb, but are you sure the lens is clean of dirt or oil, this will cause that kind of effect. If not, how old is the camera? If it is under 1 Year, I can have it repaired for you under warranty, my fee would 35.00.
Jul 31, 2011 | Olympus FE-360 Digital Camera
Stuck lense on olympus FE-350
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries
(obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
May 31, 2010 | Olympus FE-360 Digital Camera
My Olmpus fe-360 wont turn on the lens won't retract and it beeps when I try to turn it on
The lens is jammed, which means a gear is stripped or damaged, or jammed in the lens assembly, and the electronic "brain" is turning it off, since it's not in the right position (retracted). This can be caused by the camera getting bumped while the lens was out, dust, dirt, or sand can get in the lens through the front of the camera and jam it, or the batteries could be weak. After you make sure your batteries are good, and it still isn't working, go to this web page and try their suggestions. They report about 1/2 of the cameras with a lens problem can be fixed trying their suggestions. If that doesn't work, don't have it serviced- you can buy a better new camera than what you would pay a service shop.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The page says "lens error" messages, but it also applies to your problem.
Apr 08, 2010 | Olympus FE-360 Digital Camera
My Olmpus fe-360 wont turn on. The lens won't
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. A "Very Helpful" would be greatly appreciated.
Nov 23, 2009 | Olympus FE-360 Digital Camera
Our Camera was dropped and the lense was out while it was dropped. The lense now appears to be bent in a downward direction and wont retract in or out. The camera did a series of beeps and turned off. Now...
I had a similar problem with my FE 280. I just used a pair of plyers and gently straighten the lens and it works fine. You are going to pay to fix it more than the camera is worth so no harm in trying
Nov 01, 2009 | Olympus FE-360 Digital Camera
Camera was dropped, now lens wont retract, no image on screen,when turned on a series of buzzes and beeps then the camera turns itsself off.
Bad news I'm afraid. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either of these conditions causes the camera to shut off to prevent further damage, and either condition will require professional repair.
Oct 19, 2009 | Olympus FE-360 Digital Camera
Wont work!
Hi!
The focus is stuck, could be sand or something in the focus gears - well known problem with these lens. Contact your local Olympus service center and if they ask too much, feel free to contact me at toms.safranovs@gmail.com
Tom
Jul 25, 2009 | Olympus FE-360 Digital Camera
Beeps and turns off
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $48.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 02, 2009 | Olympus FE-20 Digital Camera
Olympus Camedia D-360L Digital Camera Logo
328 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
